Old 10-02-2006, 10:54 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
Default big clunk help please
i just got my car driving again and it has no brakes yet, but when I put it in drive it makes a big clunk as if it just wants to take off, idle too high? and is it because i havent bled the breakes yet?
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 10-03-2006, 02:11 AM
Pontirag Pontirag is offline
Idle too high?
I had same problem with a '74 400/th400. Had a shift kit which complicated things. fortunatly a wise old friend replaced my centrifugal weight springs on my HEI distributor and the problem went away. In fact I installed a MSD 6AL and was able to get this stock engine to Idle sooo smothly at 425 to 450rpm's that when i shifted into gear you could not hear of feel a thing. Increadable smoothness. people would come up and admire the car and then be shocked that it was running so smoothly and quietly.
But Anyway... he replaced my agressive aftermarket centrifugal spring(s?) with some other combo and the problem went away. no other tuning was nessessarry. I'me still not sure on that one but It astounded me when I thought I knew it all. Bing,Bang Boom and it was all over. Done, fixed
Old 10-03-2006, 02:30 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Could be the idle.............sounds like you may have a bad universal joint.
Old 10-03-2006, 12:57 PM
New u joints, new shaft. I have a points distributor.so is there a spring in one of these? and how do i replace it?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 10-03-2006, 05:13 PM
Region Warrior's Avatar
Check tranny fluid. Low level will cause that also.
Old 10-03-2006, 09:19 PM
ok, how many quarts do u say it might need? its got a deep pan, and it had a empty TQ vert. ive put likt 5-6
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 10-03-2006, 09:44 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
Are you sure the driveshaft is the right length? after a tranny swap my car would clunk badly in and out of gear...turns out there simply wasnt enough of the tranny yoke sticking into the trans causing slop.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 10-04-2006, 02:12 AM
well its in all the way it has a 6 in yoke i think.. so im sure its not that.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
