Think this one will hold up?
Without a doubt!
![]() Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Brian,
Looking good! Hey when you get your car together put two sets in it and give Tom V. a ride down the Quarter Mile............................he likes riding in race cars!!! ![]() |
Looking good
![]() What kind of electric water pump would you use with that timing cover? SBC? Why the switch from a stock timing cover?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Very nice.Keep us posted on the build.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
![]() Quote:
A stock timing cover does not allow for mounting a cam driven fuel pump like the Moon cover does.
"Hey when you get your car together put two sets in it and give Tom V. a ride down the Quarter Mile............................he likes riding in race cars!!! Better than drinking coffee in your motorhome while your car is on the trailer. Tom V.
That offset mag drive looks pretty trick, What mag you running?
1969 GTO Judge Ram Air III 1968 Catalina "Darkside" Vert! |
The offset is a Dunn, made by Mike Dunn of Dunn Services. Going to run a Mallory Super Mag III.
The crank pulley/hub. Who made that for you Brian?
Mike Cooper had some problems from his supplier. LOL! Tom V.
Very Nice
![]() Quote:
The pulley is a used piece I bought off the internet, I forget the manufacturer. Over the pulley is a mandrel, which is also an "over the counter" RBS piece I got from J.R. This is used in conjunction with a bearing which will be mounted to a plate that "floats" out in front of the pulley to support the crank snout. The mandrel bolts to the hub with the pulley sandwhich between it and the hub. Jon and I will be designing our own plate to mount the bearing to, just need to figure out the best approach to mount it over to the block using 4 or 6 fasteners. I'm thinking the four lowest fasteners in the front of the timing cover to build the trees off of, with two additional trees at the bottom running to the forwardmost pan bolts that are still on the "flat" of the block (and not into the timing cover). It's either that or using four trees and tying them into the front motorplate, but I'm skeptical about that, given that the plate is 1/4" aluminum. See additional pics, and here's a link to what the RCD unit for Chevies looks like: http://www.rcdengineering.com/crank_bs.html
Brian,
Which pistons rings did you decide to use in your application? TNT, Hell Fire or ? Thanks, Marty |
main webs look a little thin
![]() Quote:
![]() Quote:
https://www.facebook.com/photo.php?f...type=1&theater |
![]() Quote:
Ok I see. I don´t think that short block will give you any bigger trouble at that power level. Providing that it has a sufficient oiling system.
Will you be running it next year?
Hope to have it ready for Pontiacs in the Park 2007 at VMP. Scott Rex is pushing 1200 naturally aspirated HP with his combo, turning 8500 rpm. This one will be turning much less rpm. I've no qualms about its survivability, particularly with an average cylinder wall thickness of just over .400"
Thats cool.
Besides tha alky, how are you adressing the heat/head sealing issue with the two exhaust valves 3-5 and 4-6?
