Old 04-22-2007, 05:01 PM
1980jr's Avatar
1980jr 1980jr is offline
Default transmission linkage
hey guys does anyone have pictures or a diagram like shop manual on the tranny linkage for a 1980 trans am with th-400. i took m tranny out to put in a new torque converter and now the cable wont reach teh hole for the little bolt that hold the cable to the inkage. srry so confusing
1980 Trans Am
Pro touring build
All Detroit speed suspension tubular a arms, mini tubs, 2" lowering springs, solid body bushings, roll bar welded, smoothed firewall, corbeau a4 seats and harness
C6 zo6 brakes 6 piston front 4 piston rear hydroboost brake systems
18x9 and 18x12 billet snowflake wheels and bf goodrich kdw2 tires
Soon to be: 461 pontiac stroker 550hp with t56 magnum trans and 9" moser rear
Old 04-22-2007, 06:53 PM
fellro fellro is offline
You only dropped your trans, and put it back? Need to know what all you did, should just be held by two of the pan bolts, and with the shifter all the way forward in park, and the shift arm on the trans moved all the way in park, it should match up.
71 Lemans T37- waiting to be worked on...
83 T/A, 305 auto, rear disc
