Press Horn get a shock
When i press the horn center button i get a shock . I have the wood sport wheel . Horns work just i get this shock every time i use the horn . Anyone have any ideas as to why ?
Scott If you always do what you always did You always get what you always got |
its not grounding all the way because its arcing,
I made my brothers truck do that on purpose haha he has a 82 K10 pickup with a classic grant steering wheel, it was pretty funny because he thought something was wrong.
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
Is one of your spark plug wires lying on the steering shaft under the hood?
If so, dress the wires so they don't lie on the shaft and get worn as the shaft turns. Also make sure the firewall is well grounded to the engine and the steering column well grounded to the dash and firewall metal. George
The spark plug wires are in a aluminum holder like on hot rods. So no touching steering colum shaft . The car has a ground strap from firewall to right cylinder head and a heavy battery type cable from booster stud to back of engine. Have all grounds in place and snug. Have the ground from cluster pod to colum support snug as well .
I sure do not want to contradict George K, but besides the grounds he suggested, check the ground wire in the rag joint. It might be frayed or cracked, but horns still work. If broken completely horns would not work.
John
1965 GTO Clone 455 4 spd 1970 442 Convertible 455 auto A/C |
I will check your suggestions out at rag joint jfmjr1 .
I will also check at switch under button captainofiron .
Ok, then how about this......
Check the switch contact under the horn center button. There should be a single wire from the harness to the actual switch (horn relay wire, it may actually be a sliding contact to permit the steering wheel to turn) and a second wire that connects to the metal. Make sure that the horn relay wire is not touching the center horn button. George
Thanks George I'll give a look see and leave feed back .
