Doing it the old school way (all motor) I was curious who had the fastest Pontiac and just how fast it was. Also, whats the most hp being made without adders?
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
How are you going to compare fastest when weight, body style, chassis all come into play?
Maybe ya mean who is making the most HP N/A and seperate it into single 4 and 2-4's etc. But then you have cu.in. and on and on and on and on. |
Dude ?? Ya getting old like me...???
![]() I don't think he asked all that...just who was the FASTEST!! Would be cool to break it down to door slammer & diggers or altereds.. If they are all motor..that's it ....as long as it's Pontiac or aftermarket blocks.. I know Jack Gaydosh,Scott Rex, and John Langer are pretty damn fast...around this area. What about elsewhere ??
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
i'll start: mine is not the fastest, just an example. 526 with high ports and a victor manifold with a 1050 dominator. 8.86@151 with a 4.10 gear, nitrous grind cam, true ten tire, and stock suspension @3100lbs.
920cbhp. there are guys with a quicker settup for n.a. and also guys making over 1000hp on the motor.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension. 5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos |
I think it should at least be narrowed down to 3000# plus door car.
![]() Quote:
Scott Rex, fastest n/a. I have been 8.54 at 159.10 at 3310lbs
what about Bruce, didn't he go 8.53?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
I meant a Top Sportsman/ Ex-Prostock car with a true Pontiac motor. I STILL think it would be cool to run a Pontiac in Top Sportsman on all motor if it wasn't a maintenance nightmare.
![]() Quote:
im gonna give it a shot with my 70 gto when we get the car done. yah, even worse trying to do it with a 2600lb steel bodies car instead of a light 2350 car.
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
![]() Quote:
True Pontiac motor. Steel body. No power adders. NHRA SS legal, or?
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 06-26-2007 at 01:46 PM. |
Scott Rex 7.44 @ 186
Thats what I was asking. 7.44
All I was asking was the fastest pontiac powered racecar without power adders. I wasn't really concerned about a particular class or weight, just who had the fastest Pontiac that we know of.
![]() Quote:
Careful DUDE, dont want to be called out do you?
He'd have to spot me the weight difference.
![]() Bwahahahahahahahahaha. |
I saved this list some time ago so I'm sure it is obs. So I would say Jeff K on ALL INJUN but Scott Rex has doors.
1 John Welter 6.820@202.52 ___turbo 2 Rodney Butler 6.91@201.9 ___turbo 3 Mark Kauffman 6.92@202 ___14-71 4 Arnie Beswick 6.94@215 ___(??? I might have been 4-5 years old?) 5 Marty Palbykin 6.95 ___(???should be twin turbo) 6 Bill Mellott 7.105@198.06 ___14-71 7 Paul Spotts 7.20@196.87 ___8-71? 8 Bill Krech 7.220@189.90 ___Believe he had fogger, but might be plate NO2 9 Mike Cooper 7.26 ___14-71(Mike, I will try to call and get the mph) 10 Jeff Kauffman 7.49@175 ___On Motor KRE Sheetmetal 2X4 Dominators 11 Steve Barcek/Ron Maroney 7.50@189 ___(8-71? 10-71?) 12 Dan Sweeney 7.50@186 ___(Plate? Fogger? NO2) 13 Todd Fontana 7.58@174 ___On Motor Single Dominator Victor 14 David Butler 7.60@178 ___(Plate? NO2) 15 Shane Molinari 7.62@178___(Supercharged carb) 16 Scott Rex 7.623@181 ___(On Motor -Scott, do you have a 7.58 run?) 17 Rod Page 7.637@177.97 ___(On Motor, Dom) 18 Mike Packo 7.64@172 (Super charger 10-71?) 19 Jim Yanoski 7.708@172.9 ___(NO2 cast iron D-ports!) 20 Jim Brady 7.72@174 ___thanks for ET clarification 21 Rick Johnson 7.740@175 (619cid Pontiac biggest ever?) 22 Todd Filson 7.744@170.49 ___On Motor Single 4bbl 23 Mike Garblik/Eric Larson 7.793@17_.__(NO2 single stage) 24 Brad Smuland 7.81@175 ___(Fogger? two stages?) 25 Larry Anderson 7.90@180 ___(Fogger single 4bbl) ------------------ 26 Jack Gaydosh 7.900@179.03 ___(On Motor twin Doms)---------- 27 Kevin Swaney 7.947@167.34 ___(Single 4bbl Victor) 28 Mark Pickett 7.97@171.01 ___(On Motor Twin Sq Flange sheet metal)
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
![]() Quote:
Scott Rex...quickest AND fastest naturally aspirated Pontiac powered anything on the planet.
I know that Molinari is faster than what is posted - I think the dragster is 7.20 0r teens??
