Are there two different yellows?
Is there a differance between code 51 yellowrod paint in 1977 and code 51 sundance yellow in 1978. Did pontiac just change the name of the paint or was the color altered. Thanks.
In the birdcage: 1972 T/A, White with blue Deluxe interior 1973 T/A Brewster Green with Saddle Deluxe interior 1977 SE T/A, Black with Black Deluxe interior 1981 SE Turbo T/A, Black with Deluxe Tan velour interior. 19,000 original miles. Owned since 1984. |
Your best bet would be to run those codes past your local auto paint store, unless someone here has the info. I have seen many colors used between different car mfgs too.
I can tell you that yellows are simular to reds, in that they don't cover very well. If you paint a car with gray sealer underneath & one with White. You might have two slightly different color cars, with the same code.
68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
Just because the same paint code is used in different years does NOT mean that the color is EXACTLY the same.
Sometimes it is,but to be sure,you would need to have the mixing formulas for your code checked for BOTH years |
The 77 had an orange tint to it. The 78 was a bright yellow. Heres a link to an old picture of my 78 T/A.
http://www.70-81.com/78yellowtafull1.html
72 Firebird, sorta green, mostly gray with a red trunk lid. 14.9 @ 95mph in the Quarter mile. Street tires, highway gear open rearend. PRO Series True Street 15 second index winner 2003, 2004 Cordova, Il. |
I had a feeling the paint was a little different. Thanks for the info.
