I wanted to know where I could get a pair of tall breathers like the ones in the photo?
I want to install a pair of old finned aluminum valve covers in hopes of quieting the Rhoads lifters tick a little. Last edited by PITTSBURGH 64; 10-24-2007 at 10:06 AM. |
Hey Jeff, not sure where you'd buy the tall stacks but i'm looking breathers myself as i just bought a set of the Cal Custom covers. Not even sure i'll put these on car until i see how they look after i clean them up. Curious as to why you're going with the tall ones?
Paul
"Reason obeys itself; and ignorance submits to whatever is dictated to it." Thomas Paine (1737-1809) US patriot & political philosopher |
Pitt64 - Hope someone chimes in with some good info. I'd like a pair myself so the breathers wouldn't suck so much oil when racing. I've looked around a little for them but nothing yet. I'm going to try Speedway Racing [I think they are in Nebraska] as they have some roundy-round stuff. I believe Jim Hand uses them a bit. I'll post if something pops up.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
No luck at Speedwaymotors.com. They had Chevy valve covers with the stacks already welded in place but that was about it.
Jim
63HO, sand the covers with some 1000/1500 grit wet/dry and then run them on a buffing wheel with some polishing compound (all available at Home Depot or Lowes) and they will sparkle like new money.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() Last edited by David Jones; 04-17-2008 at 04:00 PM. |
63, I'm hoping the tall stacks don't leak.
I like my present breather set up but they are push-in. They go to the air cleaner. I might try to make a reducer and convert the twist-in to push-in and use my present breather system. Allthough the tall stacks do look cool. Looks like circle track stuff to me too Jim. Last edited by PITTSBURGH 64; 10-24-2007 at 10:06 AM. |
I'm interested in this, too. I have a set of M/Ts with about 1 3/16 holes. I wonder if there are push-in/screw-in breathers for these. The stock oil filler cap is too small.
cm
If the rules don't say something is illegal, I have to assume it is legal -- Smokey Yunick |
I don't relish the thought of sanding them with anything that's some kind of black wrinkle/textured paint between all those ribs...i'll likely just use stipper and make it disappear.
My left breather leaks a little too, but alot less since cleaning the screen. Mine are twist on style, too bad because i think these would be nice on the Cal custom cover. Maybe a bit pricey at $40+ shipping but i like that they have the correct style AC logo and dimples. Saw them on ebay but maybe our host or ames might have them just haven't checked yet. They would probably look great on top those stacks Jeff. Maybe a bit pricey at $40+ shipping but i like that they have the correct style AC logo and dimples like my originals.
just bite the bullet,buy a set of 63 SD covers with the stacks.JMHO,Tom
63, I'm going ot look into having stacks installed into my aluminum covers.
Tom, I want to quiet down the Rhoads noise with the heavy aluminum covers. |
if you use open breathers noise will come through to some extent.Maybe close off the valve covers and vent PCV into a aircleaner?Tom
I'd be willing to bet those breather towers are off some sort of factory HD truck chassis.
Something like a gas engine hot-shot truck or cab & chassis or such. They use that sorta deal as it can be hard to get to the engines to dump oil in them with some of those trucks. My guess is a good parts guy at a HD truck dealership would be able to locate such a part,the question would then be if it is still available or not. The newer ones would likely be some sort of high temp plastic or such though. |
I just made a set for my son's engine. I used the rubber baffle grommet & then a set of push in breathers. One in each valve cover. It turned out very good & it stopped pushing oil out the dip stick tube. The tubes I made raised the breathers up 1 3/4 inch but you can make them any length you want
73firebird - very clever. Got any pix to post of your ingenuity ?
Thanks, jim
In Speedways street rod catolog they have Mr Roadster crome oil fill tubes both push in and twist in for 10.00 dollars page 212 part numbers 910-17099 and 910-17098
The extensions in the Speedway cat don't have the thick hold down clip.
http://www.speedwaymotors.com/p/7772...temNo=breather The notched caps don't have enough meat for the thick aluminum covers. That Speedway cat does have a lot of cool things though. I was thinking of a pair of these and using regular push-ins and grinding away the bayonet stubs on the valve covers. http://www.speedwaymotors.com/p/5326...temNo=breather Last edited by PITTSBURGH 64; 10-24-2007 at 10:06 AM. |
this is what I came up with. He now has about 300 miles on it & not a bit of trouble out of it. The rubber grommets have a foum rubber insert in them & I took it out because I didn't want oil to soak them up & cut off their breathing I also made a plate that is welded inside to stop the oil from getting to the breathers kind of like what the old M/T had in them
