Old 11-15-2007, 05:50 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Talking OK guys - feast your eyes on . . .
some 370I / 250E KRE D-port cylinder heads.
Chamber and port magic performed by none other than my good friend Dan Barton of Westside Machine here in Houston.
Dan ordered the heads from KRE semi-finished - sans guides, seats and pushrod holes.
These heads are going on another good friend's (Walter Lansing) new engine for his '64 Tempest.
More details to follow, Walter's car is gonna FLY!
ID:	111493   Click image for larger version
ID:	111494   Click image for larger version
ID:	111495   Click image for larger version
ID:	111496   Click image for larger version
Regards,
"455HO" Lloyd
Old 11-15-2007, 05:57 PM
Redta's Avatar
Redta Redta is offline
Those are some impressive flow numbers. Good luck on the rest of the motor. Keep us posted.
Old 11-15-2007, 06:00 PM
Lloyd-TX's Avatar
five more pics . . .
Valve sizes are 2.200 and 1.660 IIRC.
Flow numbers are @ 28", .700" lift on a calibrated Superflow bench on a 4.185" bore. Walter is running header adapter plates and 2" primary headers. Dan Barton ported Victor intake.
ID:	111498   Click image for larger version
ID:	111499   Click image for larger version
ID:	111500   Click image for larger version
ID:	111501   Click image for larger version
Regards,
"455HO" Lloyd
Old 11-15-2007, 06:04 PM
sixtee8gto's Avatar
sixtee8gto sixtee8gto is offline
not sure but it looks as though he took a little too much meat out of the two exhaust ports on the first pic, on the first set of pics
-1968 PONTIAC GTO 461 STROKER
-419-841-3505
matt4530@yahoo.com
Old 11-15-2007, 06:17 PM
Lloyd-TX's Avatar
Nope.
That's why you can see he threaded two aluminum bolts in the stock location bolt holes and re-surfaced them flush. He's going to be drilling and tapping new holes further apart and corresponding wider new holes in the header adapter plates.
Regards,
"455HO" Lloyd
Old 11-15-2007, 06:20 PM
BILL BOWMAN1's Avatar
Originally Posted by Lloyd-TX
Nope.
I think he means inside the port, not the header flange.
Old 11-15-2007, 06:37 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Lloyd-
Do you have the entire flow sheet?
What comb chamber size?
Solid roller?
John
Old 11-15-2007, 06:45 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
poped into the ext. bolt hole, no big deal happens all the time if anything press in a sleeve
www.pro-touringf-body.com
Old 11-15-2007, 06:53 PM
Walter Lansing's Avatar
Walter Lansing Walter Lansing is offline
Lloyd,
You b@st@rd how dare you handle my heads before I get to see them....ha ha
Pon jon, I think they started as 85 but the chambers were larger than the bore so had to be welded and reshaped. The cam is a solid roller 276/274 735.
1964 Tempest 9.73 @ 136.9, 525, Kaufman D-Ports, Pump Gas 3670 W/Driver.
In the 9's on pump gas!
Old 11-15-2007, 07:10 PM
tstevea's Avatar
tstevea tstevea is offline
Looks like to much was taken out!Looks like he epoxied the intake side.To much meat taken for my taste
Old 11-15-2007, 07:26 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Walter,
looks like your stepping up to the next level, >Pilot< ... Good luck, it ought to fly. All it takes at cubic dollars !!! Be putting on airfoils next... May-bee they won't notice it on the runway... get a few runs in at the shop.
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 11-15-2007, 08:16 PM
slowbird's Avatar
slowbird slowbird is offline
Wink
Rumor has it that Dan has gotten 430cfm out of KRE HP heads also .
Old 11-15-2007, 08:24 PM
HMMMMMM................ I wonder who's head that is............... I head about that!!!!!!!
Old 11-15-2007, 08:30 PM
goquick's Avatar
goquick goquick is offline
The 2" primary headers is going to cost you 20-30 hp. Step the size up to at least 2 1/8". A step header would be a help too. That is great flow numbers on the intake. Mine were 340-343. My exhaust is 248 but with stock bolt locations.
Old 11-15-2007, 08:37 PM
ponjohn's Avatar
At what flow numbers do you consider 2 1/8"?
John
Old 11-15-2007, 09:06 PM
Ponjohn for me displacement/rpm range has been what seemed to matter. A small cam 350/400 does ok with 1 5/8 . basic street perf cam on a 400 1 3/4 does ok 455 street perf cam1 7/8 fine Step up to Race and 1 7/8 for the 400 2" for a 455 become minimums (if your not a tractor motor setup like Jim hands deal) I would want at least a 2.25 minimum on a 505.
Just an opinion but if using flow as a guide I would use the intake flow. (more in more needs to go out) I think most of us have seen the flow bench differences on exhaust between pipe and no pipe extension. Dont need your exhaust actin like a govenor.
Wonder if anyones got a guesstimator already worked out based on flow numbers?
Old 11-15-2007, 09:49 PM
Daniel Barton Daniel Barton is offline
The epoxy in the intake port is to fill in the void behind the guide to stop fluidic switching and to repair a dip in the intake floor that each port has... it could have been polished and the dip left in there but I didnt care for the imperfection in the casting, the head had some core shift and that is why it broke though in the one exhaust port. The camshaft is a 267-276 @ .050 solid roller .735 intake lift with a 1.7 rocker and .695 lift with a 1.6 on the exhaust.
Old 11-15-2007, 10:30 PM
J.C.you's Avatar
J.C.you J.C.you is offline
that is a very nice set of heads. biased port floors, i see the pro stock trick in the bowl too...., is that a 50* seat?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 11-15-2007, 10:35 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Dan did a little massaging on the E heads going on my 500" project. Hopefully to be finished and maybe dynoed by the end of the year.
Skip Fix
Old 11-15-2007, 10:51 PM
Bill Bolin's Avatar
Bill Bolin Bill Bolin is offline
Any more info? What is the runner volume? What are the low lift #'s? Just curious about the velocity.
