i need to take out about 12 degrees of timing from my original points distributor with a pertronix unit. if i set the initial timing at 16 degrees it has about 50 or so when revved up to 3000 rpm. when i set it revved up at 35 degrees it ends up at 4 degrees at idle and runs like poo... my plan is to weld the advance limiter so i can adjust how much the weights fly out. is this gonna work?
when you get 50 degrees of timing is that with the vacuum advance disconnected ?
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
When I was still running a points unit in my 71 GTO I ran about 41 degrees total at about 2800. You can get a Crane adjustable vacuum advance diaphram and limit total advance that way and still set your initial at 14 degrees. Also to eliminate spark scatter associated with a points style distributor you can get a composite gear from B-O-P engineering. This should help in tuning when you change over from the points. I would also recommend a MSD Blaster II coil to help fire it off.
![]() Quote:
what i want to do is be able to set my timing at around 16 degrees at idle(around 900rpm) and have about 35 whens it's revved up to 3000 rpm but i can't because there is 10 degrees too much advance built into the distributor..... also i have a msd blaster coil, new cap, rotor and taylor 409 wires |
wow that is a lot of advance
when i bought my weight's and spring's kit it came with a bushing that limited the advance to 20 so with my 15 initial that gave me 35 total and i don't use the vacuum advance
![]() Quote:
Or, most re-curve kits come with a small bushing that slips over the pin and effectively makes the slot clearance smaller. The first one I ever did, it took me 5 or 6 times of welding and filing teh slot to get it where I wanted. After you have done a few, you will be able to eyeball em pretty close the first shot. Good luck, -Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5 1933, 1934, 1936 and 1940 Fords, also Pontiac powered. |
i've got my distributor out and have mig welded closed the advance slot from .360 to .300. is this going to be too much?
nevermind i did some math and figured out how much to close up the advance slot. got it running and have initial at 14 and total at close to 40.
