used flywheel question
i replaced my used flywheel from my 70 judge with a centerforce one when i rebuilt the motor.... is it worth while throwing it on ebay or should i just scrap it? it's been machined at least once i'm not sure how much, and right now it should be machined again.....
keep it, im sure its usable
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
Yak
I'd be interested in your old flywheel . Does it fit the old style crank 68-70? Let me know i'm looking for one with 10.4" clutch. Thanks |
Using old flywheels is not a good idea because of the wear on the ring gear more than any other issue.
ring gears can be changed on old flywheels. may have a 10.5 used flywheel. Pm me if interested.
New ring gears cost half the price of a new flywheel; and that doesn't include installation if you can't do it yourself.
I have new ring gears, old flywheels, new flywheels, ruined mini starters, and small amount of experience on this subject the hard way New flywheels are the way to go; without question. And if you want to move past the worn ring gear issue; get into the fatigued metal issue of 40 year old 200,000+ mile units and see what kind of damage occurs with massive flywheel failure. |
i put it on ebay. 260207860342 is the auction number, my car only has 67000 miles on it,all it needs is a slight machining job done on the flywheel face so that a new clutch would have a nice new surface to work on.... and the ring gear is like brand new still. i should say the flywheel has 67,000 miles on it.
flywheels need scattershields anyway. but if you get 200,000 miles out of a flywheel, it deserves to fall apart since the clutch discs are long gone or throwout failed. That is not likely even if it is 40 year old. They do not fall apart due to age, metal heat fatigue and abuse are the reasons they fail. Ring gear is often an alignment issue or bad starter bushing or poor nose piece casting.
Does anyone know of someone's old flywheel blowing up. Talking about standard street once in awhile down the drag strip type car?
Not a true blow out drag car! |
SOme times there is heat stress cracks & thats what blows apart......
Get this screw job i got from a friend... he resurfaces my flywheel $75 I pay him than he states my ring gear is shot....................GREAT FRIENDS
STEVE BUDDY OL PAL do you have ring gears???????
does anyone know of any advatage to haveing an aluminum flywheel????? they are rare for pontiacs but i do come across them....
Yes I have one, but it from one of the big flywheel companies but don't remember which.
for sale????? KEEP ME IN THE LOOP
You can still buy them, I would prefer to keep mine since I may use it.
06-22-2007, 09:45 AM
steved400 Ultimate Warrior Join Date: Dec 2004 Location: Tulsa OK Posts: 2,479 Warnings: 1 -------------------------------------------------------------------------------- Got both my new Hayes flywheel and a replacement ring gear from McLeod today; very noticeable teeth difference from the stock flywheel. All three of the old stock flywheels have similar looking teeth; but I’m going out on a limb here and going to claim my flywheel failure from the mini starter was due to worn factory ring gears. I know the factory gears may not have looked like Hayes or McLeod from the start, but the teeth were probably more squared like these. Now waiting on Robb’s starter. http://forums.maxperformanceinc.com/...hlight=starter |
changing a ring gear on a flywheel is easy, all you need is a hammer punch and someway to warm up the new ring gear to get it on the flywheel.....as long as a new one is still available but it should be... |
i have a brand new SPARE mini starter... it didnt fit my narrow frame rails in my pro car if your interested... i had to cut a 1/8 off the side of the mount block & still didnt fit so i cant return it.........
i know people who weld them & file back the teeth........
McLeod 818-82-6422
Part Number F40203 I think it was around 1 bill or just under. |
