Cracked or Porosity with KRE heads
I'll try to explain this as best as possible. If your looking down at the small head stud which is between the # 5 and 7 spark plugs and you have the nut and washer off I'm getting coolant seaping through the aluminum at the 7 to 8 o'clock position where the washer would be sitting. I visually saw this. It's not coming up from the head stud. I pulled the stud out of the block and the hole is completely dry all the way down to the bottom. I just reinstalled the heads and there all torqued down. After filling the Rad and block with coolant it's almost an immediate seap from the area described. I know this can't be good any recommendations out there. Is there some type of sealer additive I can add to the coolant to seal this up.
Thanks Donald |
Have you contacted KRE about this? Can you take a picture?
68 Firebird Are you running with the wind or breaking it? |
I'm going to give all members a fair warning before you reply; THIS HAD BETTER NOT TURN INTO A KRE BASHING THREAD. All questions to help 70Man with his problems are welcome. You may also post any "FIRST-HAND" experience that you've had with this same issue. Keep any replies directly associated to this topic.
Thanks, db
Making a living is not the same thing as making a life!! |
I've had these for 2 years now and I really don't want to get KRE involved with this. I've had other issue's with these heads and thats all I'm going to say about it.
I need help with the problem at hand. Will some kind of sealer work if I put it in the coolant or will I have to try and excavate out some material and get that small area tig welded back up and remachine the surface the washer sits on. |
Is it a new build start up motor? Does it continue while running ? Get worse or less? How much water is leaking out... a stream, weeping, wet?
How high is your radiator and top radiator hole outlet in regards to the head? High Port or D-Port .
There use to be some stuff called water glass that you could by at a pharmacy, that name is a slang term for it. I think it was called silicone silicit (sp) or some thing close to that. If you talk to an old time pharmacist they will know what it is. You have to drain all the antifreeze out of the block and run only water with it and it will plug a serious leak. It will seep out and crystalize when it hits the air. I had a rad that leaked and it fixed it in no time, and I have seen it fix bad head gaskets. GOOD LUCK!
It's not a new build. I didn't want to start it yet until I got some input on this.
You can run the Moroso sealer in the heads like we used to do in the cast iron heads when rust pockets caused leaks in the ports.
I made an aluminum plate that I bolted to the deck with a rubber gasket. I put plugs in to seal the water crossover/heater nipple with one having an air fitting. Filled with sealer, presurized to 20 psi and let sit overnight. Relieved the pressure and emptied the sealer.
Dave "Big Injun" Anderson dave@4mypontiac.com www.4mypontiac.com For GTO Celebration items click the tile coaster. |
I should mention that I'm using Evans NPG coolant,and have been for several years,even before going to aluminum heads.
They are the regular D-port head,and it's a very small weep. This is happening with just the coolant sitting in the block and heads. Like I posted earlier I visually saw this happen and prior to investigating the problem I twice saw a single drop of coolant hanging on the edge of the head. It was that drop that lead me to check things out further.
When I installed my aluminum heads for the first time I had a leaky head gasket...
The block surface was fine, the heads were fine and the gaskets were new cometic's... I put in some "silver sealer" from the local auto parts store, designed for aluminum heads and/or blocks... Tha leak sealed up fine, have been running this way for over a year and hundreds of passes...
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
I'm still trying to fiugure out if the leak is a crack or a hole from corrosion. To repair it right the head needs to come off and the cause repaired. Sorry to hear the bad luck, I know it sucks. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
It's a little hard to see, even using a mirror and flashlight. I guess If I have to pull the head I would try and blank off the bottom with a sheet of aluminum and rubber gasket and then fill with the coolant I'm using and pressurize the head with some low psi air to really get a good look at it. But I'm not at the point where I want to pull the head just yet.
Thanks Donald |
dexcool's not even freindly with itself after a period of time.........
is your leak thru the threads or thru the casting? if it's thru the stud threads unscrew the stud and use thread sealer on it. if it's thru the head i'd pull it and have it repaired. mike
Dexcool works mixed with distilled water, it's made for newer cars that have lots of electricity running through them as because it guards against electrolisis better than green
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
SilverSeal or Barsleak will usually seal a weep or drip. Never used the Moroso product, heard its good too. FWIW, I believe every new car that leaves the factory anymore has a tube of stopleak poured in.
If I were having to deal with what you describe I would try the stopleak first. Nothing to lose doing that. A friend sprung a couple serious leaks in his work car a couple months ago after rearending a truck. Put in one tube of SilverSeal and he still hasnt installed new rad because the old one is still drip free. |
If it were not on the head stud/bolt washer surface (That's where it is, the way I'm reading it), I'd try to sit a ball peen hammer on it and hit it to peen the hole closed. I have fixed some leaks that way on a few Jaguars that have come thru with porous castings on various intake components.
If it is indeed on the washer surface, you might try some type of sealer...however the proper way would be to pull the head and have it welded.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
I had the same problem with an old set of E-heads. I had to pull the head and have it welded and that fixed the problem for good!
good luck!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
