'93 with a 3.4L DOHC removing plugs?
Its time to replace the plugs and wires. Is there a trick to getting the 3 rear plugs out?
I think you have to unloosen a mount and tilt the motor forward if I remember correctly.
If that car ever needs a timing chain youre in for a job -
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
Like 455Grandville says.
If you remove the dogbone mounts and loosen the coolant overflow tank, Put the car in neutral, grab the inatke and pull forward, the engine will tilt slightly to the front. If you look carefully on the firewall behind the alternator there is an arrow etched into it. You are suppose to slide a small 2X4 piece of wood there to keep the engine tilted. Safety Note: Remember to chock the tires, You don't want the car rolling down the driveway or over you.
Happiness isn't around the corner... Happiness IS the corner. 1986 Fiero SE Now ZZ4 Powered! |
