Old 04-07-2008, 12:13 PM
racerboy's Avatar
racerboy racerboy is offline
Default interior floor color - new dashes
What color should the floor pans be? Were they primered red and then sprayed black, or were they just black? I was just curious since I have the entire interior/dash out of the car.
Anybody have any info on the new dash repros? Are they any good? I have a perfect 1970 Lemans (non A/c) dash, but it needs to be rechromed and also needs new vinyl as well as the aluminum inserts along the bottom (it just has the ribs now) Not sure if it's cheaper to have that one done or buy one of the reproduction dashes.
My original dash out of the Judge was pretty beat-up. Also, is there a trick to applying the vinyl dash inserts? I tried it on another dash, but kept getting wrinkles and bubbles.
Thanks,
f.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 04-08-2008, 12:08 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
I believe the build location has alot to do with the amount of paint on the floor pans. I have a 69 Judge built in Arlington and the floorpans have alot of Carousel Red paint on them. The paint almost covers the entire inside of the floors. This is an unrestored car with 64,000 miles and I removed the original carpet myself.
John
Email jbr69gto@gmail.com
My Website www.minnesota-muscle.com
Old 04-08-2008, 08:01 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
on my judge early 69 the interior floors are a specific orange/red primer... NOT carousel overspray. the only overspray would be slightly underneath. Its possible near the door jamb area but not on my car...
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
Old 04-08-2008, 11:01 AM
dxeven's Avatar
dxeven dxeven is offline
I'm curious about this as well as my Baltimore built 69 GTO (non-Judge) had very little overspray, just red oxide primer. My Fremont built 69 Judge, which has original carpet and sound deadener looks to have carousel painted over most of the floors as GTOJohn described on his.
As for the dash caps, I cant speak for '70s specifically, but I bought one for my '69. It had a slice in it when I unwrapped it, but I put it in place to check fit. Wasn't the best. When I called Ames to send it back, the tech pretty much told me he thought Just Dashes was the better alternative, even at three times the money.
Old 04-08-2008, 11:04 AM
SONIC 4 U's Avatar
SONIC 4 U SONIC 4 U is offline
Here are a few shots as I was removing the interior from my car. Atlanta built
ID:	128516   Click image for larger version
ID:	128517   Click image for larger version
http://www.AbsoluteCleaner.com
Old 04-08-2008, 11:06 AM
SONIC 4 U's Avatar
one after
Name:	restored clutch ped..jpg
Old 04-08-2008, 01:12 PM
SWEETJUDGE's Avatar
red oxide primer thats it
Old 04-08-2008, 01:13 PM
SWEETJUDGE's Avatar
for any dash work i recommend JUST DASHES...... hope you have a piggy bank
Old 04-13-2008, 10:17 PM
GTO JOHN's Avatar
Default Judge floors
Here are the floors on my 02B Arlington built Judge. I guess it may be red oxide primer it had been awile since I looked. At least the floors are in perfect condition.
ID:	129091   Click image for larger version
John
Old 04-13-2008, 10:30 PM
Pontiac_Defender's Avatar
Pontiac_Defender Pontiac_Defender is offline
I'm still envious of your collection GTOJOHN!
Old 05-08-2008, 02:07 PM
racerboy's Avatar
My dash cover is OK. I wanted to know if anybody has used one fo the Parts Place new instrument dashes. It seems like buying one fo these for $350 would be less expensive than sending a core to Just Dashes, however, these repops come with the black pebble-grain finish and I have had no luck with installing one of the vinyl inserts (woodgrain for top) or the turned aluminim strip along the bottom on my original.
Anyone try one of these repops yet?
Old 05-08-2008, 05:56 PM
6804gto's Avatar
6804gto 6804gto is offline
Here are a couple pictures from my Fremont built 69 Judge.
These floors were all factory original never redone. Mostly had red-oxide primer with exterior color overspray from the rockers fading in toward the tunnel areas.
A baltimore 69 GTO I did a few years ago was the same way.
ID:	132067   Click image for larger version
ID:	132068   Click image for larger version
ID:	132069   Click image for larger version
Old 05-08-2008, 09:22 PM
motorcitymusclecar motorcitymusclecar is offline
Most of the 69's i have ever seen are red primer on the interior floors, under dash, package tray, and head liner area. Here are a few pictures
