Will these Cragar fit 66 Tempest
I was wondering if these will fit on all four corners. Also if they do what tire recommendations does anyone have.
Cragar 08/61 Series S/S Wheel Size: 15'' x 8'' Bolt Circle: 5 x 5'' (14mm) Rear Spacing: 4.-1/8'' 260-08865 Thanks
LJ |
If those are unilug they range from 4 1/2" to 5" bolt pattern i so than they will fit. Your's is a 4 3/4" bolt pattern.Tire size depends if you want big & littles or whatever.
15 x 8 will take some wider tires, like a 235 60 15 all the way around. Do you want to be able to rotate tires?
Illinois Outlaw Gassers 6.27@107 9.97@131 |
15 x 8 did not fit my 71 Lemans.
unilug |
Not enough backspacing to fit on the front.
The rears are also going to be tight, scraping the outside sidewall over every bump is a real possibility. A bad fit all around. I have 17X8s with 4.5" backspace (rear spacing) all around on my '64, the 235/45-17 tires are barely wider at the sidewall than the actual rim lip-to-lip width (9"). The tires are about as far towards the outside as they can be without rubbing. Low-profile 17" tires don't have nearly as much sidewall bulge for a given treadwidth compared to 15" tires. Just about any decent-size tire you put on a 15X8" wheel is going to have a pretty good sidewall bulge, you can't afford too much of that. A 7" wide rim with the same 4-1/8" backspace would be fine, but to run an 8" wide wheel you'll really need 4-3/4" to 5" of backspace. I'll never understand why so many wide aftermarket wheels are made for our cars with insufficient backspacing.
The 15 X 8 Cragar S/S's I run on the back have 4.25" b/s. On my 69 that leaves about 1/4" between the 255/60-15's I run on the back and the wheelwell. Never rub.
No way they'd fit on the front of my 69. I use 14 X 7's with 245/60-14 tires
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I've fit 245 50 16 with 4 3/4 bs wheels and also had 15 x 8 1/2 coke bottle daisy ar 200's on my 66 without problems and those had 3 3/4 bs, I don't see how the 15 x 8's would be differant .
Thanks for the help everyone.
So 15X8 4 3/4 bs will not be a problem on all 4 corners. So the next thing is what size tire..... 235 x 60 x15 all the way around hopefully without a clearance problem.
LJ |
235's is what I have - no rub unless really pushing it.
Thanks Scarebird
LJ |
Now look at Torq Thrust II I guess no unilug is better, very pricy. I guess the 3.75 backspace should be ok with 235 x 60 x15 all the way around
Part Number: ARE-5055861 Wheel, Torq-Thrust II, Aluminum, Polished, 15 in. x 8 in., 5 x 4.75 in. Bolt Circle, 3.75 in. Backspace, Each
LJ |
Even running 235/60-15 tires won't make up for the lack of backspace, those rims need 1" more backspacing to work. |
You would recommend 4.75" BS?
LJ |
Thx, b-man
LJ |
I'm curious, what wheels are on the car now?
You can always use the wheels you have now as a baseline. Find out what backspace they have now using a tape measure and a yardstick as a straightedge, and then figure your clearances for the new wheels by either adding or subtracting to find out where the new ones will sit. Your current wheels can be used as a reference to guide you along. This is very important, don't buy new wheels without getting out your measuring tape and doing some checking. Time well-spent, it could save you a lot of headches later on. Make absolutely sure that 4.75" of backspace up front won't cause the inside edge of the rim or the tire to contact the upper control arm or the steering arm/tie rod end. |
They are some after market 14x7 with 215 x 70 x14
LJ |
What do you think of this set up?
Torq Thrust II Front 15x7 5x4.75 with 3 3/4" standard backspace Rear 15x8 5x4.75 with 3 3/4" or 4 1/2" standard backspace Good deal on ebay
LJ |
