Old 07-01-2008, 09:39 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default R.A.R.E. 2.5 HO vs. PY 2.5 HO Manifolds
Hi,
This is for everyone but I hope CCass will chime in. I was wondering if there has been any side by side pics and comparison done concerning RARE and PY's HO manifolds.
Thanks,
Joe
Old 07-02-2008, 08:09 AM
The Boss's Avatar
The Boss The Boss is offline
Not to slight any of PY's products, but the RARE manifold is closer in appearance to the one carried by PY and the other restoration suppliers.
And go racin' in the street.
Old 07-02-2008, 11:50 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Boss, That's not true anymore. We are making our own manifolds now. The quality is as good or better and we have lowered the price.
About 5 years ago, HPP did a side by side comparison of the two different brands and sited small plus's and minus's of each. From a performance standpoint, their dyno tests yielded almost identical results. In that same dyno testing session, Pypes mandrel bent downpipes were tested and actually yielded as much hp(8hp) gain as the manifolds did! My point is that whichever manifolds you pick, you will be happy with them and consider taking the same care and consideration when choosing the rest of your exhaust.
Old 07-02-2008, 12:00 PM
The Boss's Avatar
Chris,
Sorry I said that - can't wait to see them at the next show - It's always a plus for us when products get refined. Any chance you can do custom date codes for an extra fee?
Old 07-02-2008, 02:29 PM
Ccass's Avatar
Administrator
Chris,
Don't worry about it. If originality is important, the some of the RA manifolds will still be the better choice. When I said better, I meant better castings, higher flow and better price. Unfortunately our manifolds were designed with performance in mind and not originality. We've brought the price down a decent amount but the trade off is we can't do date coding and such.
Old 07-02-2008, 06:31 PM
400 4spd.'s Avatar
Thumbs up
Chris, if you have figures, what would you estimate as a typical h.p. gain (67 GTO 400)when changing from original logs to a pair of R/A manifolds with your downpipes and X-pipe system, 2.5" all the way?
BTW, when I got home from PITP with my new PYPES system, I had to unpack it and check it all out. Good thing it's stainless, because I was slobbering all over it.
Old 07-02-2008, 08:49 PM
Kitch428m21's Avatar
Kitch428m21 Kitch428m21 is offline
I did notice that about you, Steve. you do seem to slobber a bit.
1970 Burgundy GTO hardtop. CVMS built 455 4sp.
May the Torque be with you!
John.
Old 07-02-2008, 09:07 PM
ponchjoe's Avatar
Ccass and others,
Thanks for the info. I was wondering if the PY manifolds are "gasket matched" and cleaned up like RARE says.
Thanks again, I love these forums!
Old 07-02-2008, 09:37 PM
400 4spd.'s Avatar
How you been, John? Got that motor back from P-body yet?
Old 07-02-2008, 09:57 PM
A-HEM.....AH, NO! (you listening mr P?) You see the ribbin' i have to take !!
Hopefully soon.
i guess I'm convinced that the same exhaust from this topic is going on when finished.
John.
Old 07-03-2008, 01:47 PM
baron_ baron_ is offline
Send a message via AIM to baron_
...don't get RARE 2.5" roundport manifolds for that '66 tempest of yours unless you want to cut a hole in your frame
the D-ports might be fine
I don't know if the PY ones have that issue - but severely miffed me about the RARE ones
One of the exhaust bosses is at the worst possible spot and hits the frame - I think their website even admits 'minor alteration potentially possible' or something - or that's what they told me on the phone maybe
(no reason for this, if they just rotated the bosses 10 degrees or so
RARE's website should say, "you're going to have to grind a big focking hole in your frame to get these to fit"
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 07-03-2008, 02:27 PM
Ccass's Avatar
Administrator
Originally Posted by ponchjoe View Post
Ccass and others,
That's one of the big improvements we're making. There is a LOT of port work done around the gasket area.
Old 07-03-2008, 02:37 PM
Ccass's Avatar
Administrator
It's hard to say exactly because I don't know your current hp but a typical GTO will gain at least 25 hp. We tested my 67 GTO (with HO manifolds already installed) with a stock 2.25"(Gardner or Parts Place) exhaust system installed for 269.6hp @ 5300 & 326 torque @ 3300 rpms. We installed the Pypes system with the Pypes downpipes and ran a 309.8 @ 5400 & 360 torque at 4000prms. You can see these results and quite a few more by clicking on this link. http://pypesexhaust.com/dynotests.html
Old 07-03-2008, 11:15 PM
form74's Avatar
form74 form74 is offline
Cass are the the castings still Classic Reproductions' or not, are they the same as the parts place ones.
Old 07-05-2008, 10:45 PM
Ccass's Avatar
Administrator
The D-ports are our own reproduction. Not CR and not PP.
