Old 09-21-2008, 01:02 PM
ta man ta man is offline
Default Pypes 3 inch
Has anyone used Pypes 3 inch driveshaft tunnel X crossover?Looking to go up to 3 inch from 2 1/2?This is on a 1980 trans am.
Old 09-21-2008, 02:20 PM
David Holmberg's Avatar
I ran a 3" Pypes system, with an X on my 77 TA and it fit very well. My TA is very low and I've never drug the exhaust on anything, I have drug the headers on speed bumps though. I now have a Pypes 3 1/2 system with an X, very nice.
Old 09-21-2008, 10:52 PM
Thanks,gonna go bigger before the mufflers.
Old 09-22-2008, 11:03 AM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
I just installed the complete driveshaft X-pipe 3" Pypes system with Race Pros on my 74. My friend spent some time fitting everything so it tucks as far up the car as possible. You can hardly see anything from the back or the sides . Quality was very good
Panos
Little Miss G Racing
Old 09-22-2008, 06:56 PM
Thanks how do the 3 inch tailpipes fit?
Old 09-23-2008, 08:35 AM
They line up pretty good. I'll take some pictures.
However, in my instance the kit did not line up perfectly with the offset/offset mufflers. I had to get an offset/center muffler for the driver's side to make sure everything fit perfectly, and tucked up as high up as possible. I guess we could have made it work with the offset/offset muffler, but we didn't like the way everything hanged down, and came close to rubbing the body. I think the tailpipe was not bent correctly making this change necessary.
Panos
Old 09-23-2008, 02:13 PM
I've run 11 in wide tires on 10 in rims and they don't hit or rub at all.
Old 09-23-2008, 06:25 PM
Thanks guys ,may just upsize in front of mufflers.I'll see how it gains currently running ultraflos and 2 1/2 mandrel flowmaster tailpipes.
Old 10-06-2008, 03:14 PM
If you still need the pics, here are some:
Correction on my previous post, it was the passenger's side that needed the offset/center
Panos
Old 10-06-2008, 03:27 PM
COMP COMP is offline
looks good
Old 10-06-2008, 05:05 PM
Thumbs up
Looks good may go up to full three inch exhaust can use old exhaust which is in mint shape on new project.
Old 10-06-2008, 05:07 PM
Just noticed was there a reason for the center exit muffler on the passenger side?
Old 10-06-2008, 09:43 PM
71firebird400's Avatar
71firebird400 71firebird400 is offline
See Post #6.
Mark
Old 10-07-2008, 07:39 AM
Larry Navarro's Avatar
so, you ordered and installed a complete system and the tailpipes couldn't be lined up?
Strange.
Old 10-07-2008, 08:04 AM
Strange.
Yes. Actually it was more convoluted than that . The system came with the wrong x-pipe setup (the wide one vs. driveshaft tunnel version,) which made it impossible to install anything. We got the correct x-pipe, and the tailpipe just was not going to line up perfect with the offset/offset muffler. We are guessing the tailpipe was not bent 100% correct necessitating the different muffler . However, if I was not anal about ground clearance, we could have made the offset/offset muffler work. Either way, BSM Exhaust (the vendor) took care of the problem, and I couldn't be happier with the way the system came out
Panos
Old 10-07-2008, 08:47 AM
I install all my exhaust myself so a fitment issue wouldn't be good.
Old 10-08-2008, 11:55 AM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
You got any sound clips? That sure looks cool..
_____________________________
www.classicpontiacrescue.com
Old 10-08-2008, 01:44 PM
I don't. I'll get a clip over the weekend.
Panos
Old 10-16-2008, 07:43 AM
Well definately need 3 inch exhaust now.Have a comp cam 290b cam coming along with some other changes to car.Going to need to let her breathe more.Have a little grudge race next year.Going to be sneeky .
