Old 10-12-2008, 01:22 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Question 68-69 M20 Muncie vs 77-78 T-10 M21 BW ?
These do interchange freely right? Which one do you prefer? Which is stronger?
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a
66 Star Chief Executive 57k mile
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
Old 10-13-2008, 07:46 PM
I have not owned any T-10 cars but don't they use a larger TH400 sized output shaft?
If I run a old M20 in a 78 car , It should hook up like a th350 as far as driveshaft requirements and crossmember.
Old 10-13-2008, 08:00 PM
2manyT/A'S's Avatar
Super T-10's DO have the larger (TH400) outtput shaft & fine spline input.
Dimensionally they WILL interchange,same mount/crossmember,driveshaft length,etc.
If you are in the habit of side-stepping the clutch pedal OR shifting WITHOUT IT,your Pontiac 400 or 455 is capable of breaking EITHER!
The Super T-10s with the taller low gear ratio's ARE inherently WEAKER.
SuperT-10's (for the most part) will be 10 years NEWER than MOST Muncies,so it's possible that you'll get a "tighter" or lower mileage unit.
Muncies shift a little nicer/smother than the ST-10.
