Old 10-12-2008, 06:57 PM
mguerci mguerci is offline
Default '78 GP Stock Ride Height
Does anyone know the ride height of a '78 GP with stock suspension? Specifically, from the wheel center to the top of the fender well, front and rear, if possible. I'm tyring to tackle a couple of issues:
front wheel rubs fender on top on full turn, full compression
back wheels are about 3/4 different in height at rest
what the true stock position is so I can determine that amount of drop I want when I redo the suspension.
I'm trying to seperate wear and sag over the years from stock dimensions.
Old 10-13-2008, 01:37 PM
srercrcr's Avatar
srercrcr srercrcr is offline
My 78 is bone stock. It's approx 14 1/2" on all four wheels
Old 10-13-2008, 03:55 PM
engineer engineer is offline
the specs for ride height are in your factory service manual. Did you check there?
Old 10-13-2008, 07:15 PM
Default '78 GP Lowered Stance Specs
I checked in my manual, but couldn't find it. Maybe I missed it. Thanks for the info.
Does anyone have any pictures/specs of their lowered GPs so I can get an idea of how things look? I'm running 215/65R15s on 15x7,4.25 bsp Rally IIs. The drive train is a 400 w/ TH350.
Old 10-15-2008, 09:56 AM
shotgun shotgun is offline
PY Staff -Tech
Hope this works, should help.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
