#281
Old 02-15-2014, 10:08 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Yep, not going to use it. It would be great fine with a small body distributor and most set-ups. I just double up the 1/4" thick gaskets under the carb to help with the Shaker not fitting well thing.
Still going back to the ported HO intake, which is plenty of intake for what I'm doing with this set-up.....Cliff
  #282
Old 02-15-2014, 06:50 PM
David Jones's Avatar
Mine fits with a factory HEI. It's tight .
  #283
Old 09-04-2014, 05:50 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
It went to a good home!
[IMG][/IMG]
Hopefully it will clear my HEI. Looks like someone already grinded the rear runner a bit:
[IMG][/IMG]
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #284
Old 10-19-2014, 10:26 PM
AdamIsAdam's Avatar
Installed. Runs very strong. Looks good. HEI fit (BARELY) with a bit of filing down on the distributor cap.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Thread Tools
Display Modes
