Does anybody have a picture of the oil filter adaptor that is used to angle the oil filter in a different direction to clear the exhaust for the Ram Air 3 long branch manifold set up on a 400 motor? I recently installed a pair of long branch exhaust manifolds on my 68 Firebird and I am having a clearance issue with the oil filter and the exhaust manifold hitting on the passenger side. I have the 90 degree vertical oil filter housing on there now. Will the oil filter adapter solve the problem or do I have to go with the remote oil filter adaptor set up? Has anybody tackled this problem before? Thanks in advance.
68 Pontiac Firebird 400 ![]() ![]() |
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
You need the Ram Air oil filter adaptor that bolts between the oil filter base and block. Performance years sells the adaptor as a kit and it comes with everything you need.
PY part # is RFE96 cost $50. Well worth the price and it will solve your clearance problem.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
i posted pictures of this a while back on this thread. i showed a comparison of the big car one and the firebird also. here is the link.
http://forums.maxperformanceinc.com/...d.php?t=585913 |
Thanks for all your help!
