rebuild distribution block?
I am redoing much of my brakesystem on my 69 gto and wondering if i need to rebuild my distrbution block or metering valve?
Nothing to rebuild...just flush it with brake cleaner and you are set.
Thank you George ,how about the hold off valve?
You can flush the hold-off if you like.
There are no rubber components to relace?
I meant replace
There are rubber o-rings/seals in the combo valve and hold-off...but they usually never go bad....flush with fluid until you get clear fluid and you will be ok.
