Old 04-06-2009, 03:11 PM
bb400ho bb400ho is offline
Default need help on a 89 blazer 4.3
i have an 89 blazer with the 4.3. it has a tick that is driving me nuts. i thought it was the timing chain and changed that and the lifters it is still there. it is a tick and doesnt sound like a rod knock. if i put it in gear and power brake a little i cant hear the tick. at idle i hear it pretty good. the oil pressure is 25-30 at idle. any ideas?
thanks bryan
Old 04-06-2009, 04:50 PM
Lifter?
Mike
former." --Albert Einstein
- Winston Churchill
Old 04-06-2009, 05:25 PM
stimpy stimpy is offline
cracked manifold or exaust leak ....
Old 04-07-2009, 12:12 AM
cuz68's Avatar
cuz68 cuz68 is offline
Unhappy
Cam. you said you changed the lifters.
Old 04-07-2009, 12:22 AM
Jim Scites's Avatar
Jim Scites Jim Scites is offline
Might be a crack in the flex plate?
Go Fast... Return... Go Fast Again... Who cares about left turns???
Old 04-07-2009, 02:02 AM
cuz68's Avatar
I thought of that also.
Old 04-07-2009, 02:41 AM
fried boloney fried boloney is offline
I believe some of those had sloppy rod/ wrist pin fit. I used to work at a Chev. dealership
Old 04-07-2009, 08:45 AM
Default 4.3
thanks for the replies, the lifters are new, the flexplate is also new, it had a spot where the teeth were missing and it wouldnt engage the starter, i dont think its an exhaust leak, cam is a possibility. wrist pin hmmm. i forgot to mention that it is sporatic. sometimes when i start it it doesnt make the noise even at idle. but once it starts it stays. would wrist pin or cam fit this pattern?
thanks bryan
Old 04-07-2009, 09:43 AM
Seems like I remember another issue of pistons being undersize. Can't really remember, it's been quite a few years
Old 04-07-2009, 11:13 AM
goatnut's Avatar
goatnut goatnut is offline
Your right. But also the fuel lines run up the trans tunnel and make a loud ticking noise. I remember when they first started putting the 4.3 in them we had sold one new and the customer brought it back complaining about the ticking noise. That is just a carrieristic of the beast. How long have you owned this blazer? Did this noise just start or has it always been there? The reason I ask that is you may have disturbed the fuel lines while working on the engine.
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
Old 04-07-2009, 11:22 AM
i82much's Avatar
i82much i82much is offline
Great engine but hey it's an 89. Rather than buying a bunch of parts chasing some little noise that won't go away, buy a louder radio and drive it til it dies!
Old 04-07-2009, 11:45 AM
I've also seen Idler pulleys make this type of noise. They normally don't come and go tho.
- Winston Churchill
Old 04-08-2009, 01:21 AM
cuz68's Avatar
Wink
Did they teach you that when you change the lifters you change the cam also? They do go hand on hand right?
Old 04-08-2009, 08:56 AM
md1twal3 md1twal3 is offline
From the new parts you installed, sounds like your removed the engine or trans (flexplate replacement)?
I recall the exhaust pipe to manifold donut sealing being a bear to seat from time to time. Used to take a brass drift against the flange and hit it with a hammer to seat the donut.
Depending on how warm or cold it is when you start it, the noise will vary.
If you wanted to check for an exhaust leak quick, drop a couple of splashes of trans fluid down the throttle body while it is idling. The smoke will come out the areas where it is leaking.
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 04-09-2009, 03:34 PM
Default 4.3 noise
i checked again to be sure its not an exhaust leak, its not. i ran it without the belt and it still makes the noise. i know i should be slapped for not changing the cam at the time i changed the lifters but i thought one was not pumping up or something like that.they have rollers on them and there was not any visible wear. at one time this was my fathers blazer and he had a new shortblock installed. i think it has about 50-60 k on the shortblock. im thinking about the wrist pin or piston slap. oh the stereo turned up does work well... i think ill wait untill whatever it is breaks
thanks bryan
