'71 A/C and heater vacuum lines question
Here is a pic of the three vacuum lines that come through the firewall. where do the red and black lines go to? I am guessing black is the vacuum source and red goes to the heater valve. Is that correct?
Thanks, Rick |
Basically,...yes. Your FB must not be a fairly late production since it has the water control valve. Later production, like '72, did not use the valve, so only had two vaccum hoses routed throught the firewall grommet.
The '71 Shop Manual shows the Black tube running to a vacuum check valve, then to engine vacuum. The light Gray, probably your White, goes to the purge diaphram, & the Maroon, your Red, goes to the inner fender mounted water contril valve.
vacuum lines
black goes on the back of carb (should have a one way check valve) white is in the correct location. hope that helps. |
There must be an echo in here!!
Thanks guys. Tramsamric, you are correct. My car is a January 1971 build.
Rick,
Where does your red (maroon) vacuum line connect to once inside the firewall? I have a May 1971 built firebird and only have a gray and black line coming out. However I do have a water valve that needs a marron tube connected to it to make it work. |
Additional proof of this is the 5/8" heater hose that ran from the heater box to the rear of the passengers side head had a different part number(because it was one solid piece, not 2 pieces seperated by the water control valve as in 1970). The 1970 hose number is 482482 and the 1971 hose(5/8) # is 509043.. The valve you are talking about is #9774799. It was used on late 1960's Pontiacs also, but was not used starting the 1971 model year any longer. Your firewall should not have the maroon hard vacuum line comming out from any 1971 Firebird. This is clearly stated in the assembly manual. Could you have an early(late 1970) car that still has the 3 vacuum line(including the maroon one) I guess.. But with the strike late 1970, I seriously doubt many, if any, cars were assembled with the incorrect 3 line vacuum hose set up(should be 2 like one member listed)..The grey goes to the large vacuum cannister on top of the heater box and the black goes to the vacuum tree at the rear of the Quadrajet and should have a black one way check valve inline between the carb and the hard vacuum hose using a small section of tiney soft rubber hose. I am sure others will disagree with me.. But look on an original 1971 passengers side inner fender, you will see 2 dimples where the heater valves bracket would have gone. They will not be punched oput on a real 1971 inner fender.. Like I said...I am sure others will disagree with me.. Just like there are those who insist that all 1971 HO's used the idle stop solenoid, which they didn't.. automatic HO's didn;t for sure.. So this is my 2c's .... |
Maybe 71 is the change over year. If you look at these pics I see the maroon line going to something on the wheel well, The picture is a 71TA HO four speed, I can take more pictures if I need to.
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air Last edited by wwilder9; 07-04-2009 at 11:03 PM. |
Thanks 70RAIII....you described everthing I have; only 2 lines (Grey and Black), a plug in the third hole on the firewall gromet and dimples on the fender well for the heater valve braket . Someone just installed a water control valve on my car thinking it was required...I'll take it off. Does the 5/8" hose have a pre-formed 90 degree on it to make the turn back to the heater box? I also noticed my black line going to the carb vacuum tree is missing the "check valve". Do you know where to get one of these? I'm wondering if this might be causing a slight vacuum leak that occasionally causes misfire/hesitation.
As far as pictures showing what look to be original cars with the 1970 style set up... one of two things.. really early made 1971(like 8/70 or so) or a car that was rebuild years ago and has had miles put on it. I bought a car 4 years ago that I just new was "as found" original.. had all the grime etc in the right places.,.. just looked right.. started taking it apart(it was a formula I was using for parts) and dam'it if this stupid car had been rebodied at some point. The hidden vin numbers were wrong.. So just because a old grimey car looks like it has never been touched doesn't mean it hasn't. I learned this with that formula.. So many things could happen over 30 years.. So the picture shown is eaither an early car that still used old parts or has been rebuilt at some point years ago(I am positive I will get arguments with this comment, but it happened to me...) |
I'll try to get some more pictures of my car to see if it has been altered or messed with, Like 70RAIII said "So many things could happen over 30 years..".
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
by no means am I trying to make the point that your car is infact not original. There is no way I could do so without seeing it in person. I just know the experience I had with that parts car 4 years ago. I just knew it was all original, grime/rust in the right places etc.. the whole rear end was rusted out(otherwise being a formy I would have restored it !!) But it is a fact that the 71's were spec'd out not using the heater valve any longer as they did from 1970 back to something like 1967 or so.. Wwilder9...I learned a long time ago never to say never when it comes to our cars. Yours could have easily been made with 1970 harnesses and heater valve. But I guess the main point I was trying to make is that the Firbirds were spec'd without the heater valve in 1970,hence the 2 hard line vacuum lines vs the 3 hard line vacuum set up. I have seen original cars where people have added the heater valve,and idle stop solenoid on auto cars for that matter, thinking their car was incorrect and trying to make it correct. Anything could account for your 1971 car having a heater valve. I could see in hot climates people adding the heater valve to help with the a/c system... Where was your car made and when?? I have seen Van Nuys cars that have continued using parts from previous years....Your car looks like an "as found" car with all teh rust and grime in teh right places-sans the black scoop.. Anyway, please do not take my comments as a swipe against your car.. It wasn't meant as such.. |
Does anyone have a picture of the black vacuum check valve and what vacuum port on the carb does it terminate at?
http://www.starspangledbannerchallenge.com/ |
I took out the water control valve and inserted the vacuum check valve...heater works great. Now I'm not getting any air from the dash vents. The door in the heater core (inside, under glove box) will not move when I switch from any of funtions on the a/c control panel. which vacum line contols this function?
Anyway, I will get you a picture of one later this evening... |
ALso, the vacuum from this check valve goes to your HVAC switches and controls all HVAC functions. It is a vacuum operated system. I still think you have the check valve inserted incorrectly. Try hooking vacuum line up without the check valve and see if everything works. Make sure you are getting vacuum to the point you are hooking it up to. It needs to be full vacuum at all times, not a ported vacuum source.If it does work doing this test, then your check valve is either inserted in the wrong direction, or the valve is not working.. It will not harm the system to run without the check valve for this test...
I ran a straight line without the check valve and still did not work. I was thinking, I might have pulled a vacuum line when I was under the dash however, I double checked and every vacuum line is accounted for. It was blowing right before I took off the water valve and replaced the heater hose going to the case. Is it something electrical that conrtrols the movement of the heater case door ?
Here's a pic of the passenger inner fender from a Jan. '71 Van Nuys 455 HO Formula. There's a valve and bracket that appears to be original. I don't know the history of the car from new though.
Then again, as I said-and no disrespect to anyones cars, you never know what has happened to a car over 40 years. A car could have been completely rebuild in the 1980's, driven another 50k miles and to us, would easily look original"as found" condition... I learned my lesson with that formy 4 years ago.. Truth be told, I was embarrassed to tell anyone that story until this thread. I paid more than I should have for that car just knowing it was an original, as found, complete formula 400. The body,especially the rear/trunk, was rusted to sh!t, but everything else looked ok.. I just knew I was going to get a bunch of good parts from it.. Ended up having all kind of miss matched parts.yes, I learned my lesson on that one.. Just because it looks original doesn't mean it is.. A previous owner could have added that heater valve easily if they were using the car in a extreme hot enviroment (Southwestern US,Lower Texas, Florida etc..) to keep the hot water out while using the A/C.. Still don't know why Pontiac quit using the valve...Just a $5 valve and a couple clamps and an extra foot of 5/8 hose -$10 production cost at most... |
