Old 07-28-2009, 03:45 PM
Trump Trump is offline
Default wanted: Fenderwell headers that will fit a '59 389
Looking for a set of fenderwell headers that will fit a 1959 pontiac v8. Willing to buy or trade. If you have a set that is available, please let me know. thanks.
Old 07-28-2009, 09:43 PM
ponchospidel's Avatar
ponchospidel ponchospidel is offline
Exclamation
my dad has a set of DOUG's fenderwell headers that were made "back in the day" that were bolted up, but never ran.
he said he would take $450 for them or consider a partial trade. we can bring them to Norwalk.
give him a call 765-534-4140, or email at pontiac.lady@hotmail.com his name is
Terry.
hope we can help,
Bread Spidel
1973 ventura pump gas street car -NA-10.68@126.6mph/ N2O-9.97@136.6, 3645#
1968 procharged firebird 5.66@123mph 1/8mile-F-2(22#boost), CSU E-85 carb, 477 IA2, 315cfm Butler E-heads, and factory suspension, 3580#. 939RWHP@25#boost
thanks to Butler Performance, CSU carbs, and All Pontiac.
Old 07-29-2009, 01:09 AM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
Please show me pictures of these! I've never even heard of these. I had to make a set
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 07-29-2009, 03:27 PM
Default pictures
they are 1.75" and 3" collector
ID:	176404   Click image for larger version
ID:	176405   Click image for larger version
Old 07-29-2009, 07:19 PM
WOW Those are insane!!!
Robert Lewis
Old 07-30-2009, 07:31 AM
PLAY400's Avatar
PLAY400 PLAY400 is offline
So are any of you jumping on them or are they still up for grabs. I'm interested if they will fit a 55 Pontiac with a 455. Alan
Old 07-30-2009, 09:57 AM
hellerods's Avatar
hellerods hellerods is offline
Default fenderwell headers
Yes, I called Terry yesterday and he is going to check fit for my application and then send them on their way, I hope That they fit my car. Terry was very interesting to talk to and I just wished he lived closer I would love to meet him and his wife in person , they are both drag racers to the bone!!
Old 07-30-2009, 04:33 PM
I'd love to have those but I can't pull the trigger right now. If you pass, let me know and maybe I can make it work
Robert Lewis
Old 08-17-2009, 10:10 PM
Scott M's Avatar
Scott M Scott M is offline
Question
What's the big attraction to fenderwell headers?
Besides having the opportunity to butcher up a nice pair of inner fenderwells, I mean?
Old 08-17-2009, 10:26 PM
in Most cases, people remove their inner fenders before running them. So don't worry. I'm sure poison heart had his reasons for whatever modification he did to his own. Fenderwell headers make it easy to get around the obstacles you would normally have to negotiate by going between the engine and frame rails. They are usually used on cars that will see some time on the drag strip...... Could also be used on cars running lake pipes.
In my case, the motor is not even going in a pontiac and the car it is going in never had inner fenders when I got it.
But if you are the numbers matching, factory bone stock type of person, I could see how you wouldn't understand.
However it all comes down to, "it's your car, do what you want with it".
Old 08-18-2009, 05:02 AM
If you have a 59 Pontiac and you NEED headers then that's the best way to do it. The frame on the '59 Pontiacs are just way too low and no way around them unless you go under them or go through them. Under the frame puts your exhaust about 3" from the ground. You couldn't drive over a speed bump. Not to mention how hard it would be to snake 4 1 3/4" primary tubes around the starter, the steering box and the pit man arm and then around the frame. I'm not entirely sure that's even possible.
And I think they just look cool. I don't think it's worth doing just for looks though.
And I didn't have to cut too much of my inner fenders. Who cares?
Robert Lewis
Old 08-18-2009, 07:45 AM
Scott M's Avatar
Question
But, if you use this type of header, doesn't your exhaust system STILL have to go BACK underneath the frame, causing ground clearance problems farther back?
Old 08-18-2009, 09:02 AM
Who cares?
Exactly! Your car, your taste, your business. You know how you want to build your own car. There's no need for Armchair quarterbacks telling you how you should do it.
Old 08-18-2009, 09:06 AM
Not necessarily. Fenderwell headers many times are run open for track use. So no need to worry about mufflers and tailpipes. If you do hook them up, most would run them on the outsides of the frame with side pipes that exit in front of the rear wheels. I have no idea what Poison Heart's setup is, but I'm sure he's got it under control. My headers will be run open with no additional exhaust.
Old 08-18-2009, 02:49 PM
No, The headers don't have to go back under the frame. 59 Pontiacs have an X frame and the only place for the exhaust to run is on the outside of the frame. If you go OVER the frame then you don't have to go UNDER it.
I'm going to run exhaust but I'm not sure how far back yet. I'm going to put cut outs right after the headers though and then run glass packs and probably dump it before the axle.
Robert Lewis
Old 08-18-2009, 03:53 PM
Sirrotica's Avatar
When I was about 12 years old I had a neighbor with a 63 Impala 409, dual quads etc. and I watched him build and fabricate headers and exhaust for it, 58-64 full size chevys have the same problem and it's caused by the X frame as was already stated.
For those not familiar with X type frame cars the full exhaust system is hung outside of the X under the floorboards. The original path kicks the front exhaust pipe outside of the frame rails just behind the lower A frames, which there isn't sufficient clearence to exit 4 header tubes and a collector. Hence the need for headers that come over the frame rails and then rearward to be transitioned into the exhaust.
I have followed Poison hearts header build at another forum and he has done a good job for someone that has nearly no experience in header or exhaust fabrication.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-18-2009, 04:12 PM
Thanks Sirrotica! My headers aren't perfect and neither are my welds and the left and right side are not symmetrical but they look ok. Maybe a few years down the road I'll build a better set. I kind of wish I ground down all the welds flat but at the time I thought the welds would look cool. Oh well
Robert Lewis
Old 08-18-2009, 04:33 PM
Sirrotica's Avatar
NP Bob, in case you've not noticed no left and right headers mirror each other due to different obstacles on either side of the frame and engine.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-18-2009, 04:38 PM
Yeah, that's true but I think if I tried hard enough I could have made them match. I'm satisfied with my final product though. I think for my first set they're not bad. The next set will be better
Robert Lewis
Old 08-18-2009, 05:26 PM
PLAY400's Avatar
I think they look great Bob even with the welds showing. Since these sold I may try to make a set for my 55, 462, out of a set of BBC fender well headers for the tri5s. To answer Scott M. "cause they look good in the car, make it a little different than everyone else's and the car will never be a record breaker so I ask you why not?"
