Headlight Problem on 66 Pontiac Tempest
Replaced headlight switch....I have tail lights , but headlights don't come on...what could be the problem....Brake lights and blinkers work fine.....
Check for power and ground at the headlights first. All you did was change the switch? Possible that a terminal on the switch plug came loose. Check for this by removing the switch with plug attached, then you can see it a lot easier.
"GTO......Gas, Tires and Overdraft"! '70 GTO convertible, 434, 4-speed |
Headlights
Try your floor mounted dimmer switch.
Another Red Light Nightmare 1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw 1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project. Semper Fi |
Did the headlights work before you changed then switch?
