Front coil springs
I am changing out the front coil springs on a 70 lemans sport. I ordered a set of moog 5440 springs through moog. I was told that was the one I needed, when I opened the box I looked at both ends and they are both round. The ones I took off are flat on the end at the top and round on the bottom. I have already returned one set already for being to big, will I be able to use the ones they sent me or do I have to return this again?
A 1970 LeMans Sport with a V8 takes a Moog 5382. This spring gas one 'flat' end and one 'pigtail' end, which is a requirement for your car.
I would recommend you contact Kevin at Coil Spring Specialties in St. Mary's, Kansas. They will make custom coil springs to order for around $150.00/pair...Robert Last edited by Z Code 400; 01-26-2010 at 11:05 PM. |
Thant site made me Hoppy!
Checked out that Coil Spring Specialist website. I;ll have to think about that option myself for my 65.Looks as though they've got the ability and experience to give you exactly whats needed.
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ |
Front frame
Finished up the front end, except the front stabilizer bar. I need to torque the lower control arm bushing bolts on each side, the service manual says torque at curb height. To me that means installing the tires,and putting the weight on the frame, correct me if I'm wrong. |
it mens you must have ALL the weight on the suspension and on it's wheels, from the pic you are missing close to a couple thousand pounds
www.pro-touringf-body.com |
Replacement springs should not cost more than $75.00 a set. Depends what you are trying to do. 5436 is the stiffest (I think that is the right number) followed by 5450 (Chevelle SS springs) Next is 5400. I would put in 5400s with one coil removed.
5400 is what I use in a Pontiac V8 A body. I cut different amount of coils depending on the year unless you want the front end in the air look. 1 coil removed for a 1970.
Thanks very much for that info!! St. Marys KS is not too far away and I need springs in my Chevelle (Pontiac powered of course). I bought some cheap ones from carquest and now my car sits crooked. Cant take em back cause I installed them, .
better than that even
)there @ SCC and think about his springs. I really gained info from talking to him and his products are great.
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ Last edited by dracowizard; 02-05-2010 at 03:43 PM. |
Your car would not sit crooked because you bought springs from Carquest. There is something else wrong.
How much 'front in the air' over stock? I want to raise the front of my 65 GTO about 1-2 inches.I will also raise the rear to set it level.What about 5272?
I want to lower them down not raise them up. You would have to cut 1/2 coil off for a 65 so they sit in the spring pockets right. The 68 and up springs are 1/2 coil off from the 67 and below springs. The wire diamter is also larger on the 5400 springs.
JC Whitney sells high lift springs.
