PONTIAC ALUMINUM HEADED 467 700 HP PUMP GAS MOTOR GRP ALUM RODS EAGLE CRANK JE
PISTONS 10.8 COMPRESSION BILLET MAIN CAPS SOILD ROLLER STUDED MAINS VICTOR 4500 INTAKE WITH 1050 DOMINATOR RACE PERP BY TONY WILLISON A SET OF SD PERFORMANCE RACE PERP HEADS DONE UP WITH GOOD FLOW NUMBERS TO MUCH TO LIST IN MOTOR I WILL LET YOU KNOW THAT THIS MOTOR MAKES AS MUCH TORK AS HORSE POWER THIS IS A SERIOUS PICE FOR A PUMP GAS MOTOR WILL GIVE SPECKS OUT TO SERIOUS BUYERS RACE PREP TH-350 WITH ALL GOOD PARTS WITH ULTRA BELL WITH 8 INCH ATI 76 PONTIAC TRANSAM CUSTOM INTERIOR ALL AUTOMETER GAUGES 6AL MSB BOX WITH TIMING CONTROLER COMP 250 FUEL PUMP 12GAL FUEL CELL CUSTOM PAN UNDER CELL ALL BRAIDED LINES FROM FRONT TO REAR BM TRANS COOLER HURST PRO MATIC SHIFTER 12 BOLT 373 GEARS WITH TA COVER DRAG SHOCKS ALL THE WAY AROUND CUTOM MADE SWITCH PANIEL TRICK FRONT SPRINGS ALL NEW BALL JOINTS NEW CONTROL ARM BUSHING NICE PAINTED FRAME AEROSPACE FRONT DRAG BRAKES BORGESSON MANUAL STEERING BOX NEW CUSTOM EXTENDED TRACTION BARS I WILL TELL YOU WITH THESE BARS 60 FOOT TIMES 1.40 TO MUCH TO LIST THIS WILL MAKE SOME BODY A NICE PICE PICTURES DO IT NO JUSTED SERIOUS INQ ONLY THIS CAR WORKS VERY WELL WON MANY RACES Seller Phone Number: 504-342-6892 Seller Phone Number2: 985-651-0292 ![]() |
Our for sale adds require that you include a price. Please do so or this post will be deleted. Thanks.
db
Making a living is not the same thing as making a life!! |
![]() Quote:
