Can anyone tell me what the size of the bolts are for a 1974 400 timing cover Bolt size and thread I need to know
1980 Trans Am Pro touring build All Detroit speed suspension tubular a arms, mini tubs, 2" lowering springs, solid body bushings, roll bar welded, smoothed firewall, corbeau a4 seats and harness C6 zo6 brakes 6 piston front 4 piston rear hydroboost brake systems 18x9 and 18x12 billet snowflake wheels and bf goodrich kdw2 tires Soon to be: 461 pontiac stroker 550hp with t56 magnum trans and 9" moser rear |
Well, timing cover to block are 3/8-16, with two 3-1/2" long and two 2-1/2" long. The factory studs are 4" long and are 3/8-16 (course) on one end and 3/8-24 (fine) on the other. Then there are nine 5/16-18 bolts that are 1-1/4" long holding on the water pump (other two bolts for the 11 bolt water pump are the large 3-1/2" bolts mentioned above). Only other bolts are the bottom four 5/16-18 bolts 3/4" long holding the pan to the timing cover.
