Oil Filter will not clear header
I cant get my oil filter back on after installing headers .any idias?
I put a long brach filter adapter on my 69 GTO,tilts the filter back and is EASY to change.Tom
press the "search this forum" button and enter
oil filter header as the search term. You'll find a LOT of info about this problem.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Won't fit or don't have room to stick it up there?
Besides the hang down touch clearance problem, WS6 F bodies can be a PITA with some headers. Mine now you have to slide the filter back beside the transmission to get it up and down. You have to use your imagination at filter change time to cut down on the oil mess. Like covering the header up to keep oil off of it, quart freezer bag to catch the filter in, etc., etc..
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
I think a smaller filter would fit.are there any small oil filters that would work on a Pontiac.I am also running a high volume and high pressure pump.thanks for all your thoughts.
NAPA Gold #1522
The hight is not a problem it is the diameter.I will check out napa 1522 thanks
What are you running for headers?
super comps.
6.0 Chevy truck filter works fine, just as long but 3/4 the diameter. The Fram # is 3675 cross to whatever you want
What size? I have 1 3/4's no problems.
K&N HP-2006
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN |
I have one set of Super Comps 4202s that one tube wouldn't allow the oil filter to come off or on. It is my 3rd set. Luckily they are my dyno set and it was easy enough to pull the headers to change the break in filter. I had to beat the tube pretty good. You can see one bend is not the same as another set has so the tube goes by where the filter is.
Thanks for all the thoughts.I have 4109-1hkr, I did get the smaller oil filter to fit.I cross referenced the oil filter suggestions to a amsoil eao-30 and it fit.I wont know if I will have any problems until I finish rebuilding the carb.Thanks again to everyone.
I mounted a remote oil filter on my firewall, want me to post a pic or two????
Can do the talk, can't do the walk......therefore need deep pockets Injection is nice but I rather be blown If you got it flaunt it, if not fake it (Snoopy) Original 1977 Firebird / Welded tube frame connectors TH350 with shift kit / 400 bored/stroked to 455 by PDude OCD=Waxing and polishing your oil filter SICK=wetsanding your exhaust pipe |
Sure, I would like to see your set up.Thanks
I have a similar issue in my 69 Bird with Headman's does anyone know if there is an alternative to using a remote setup?
pics
I don't know. I have a 69 Bird with Doug's round port headers and was able to fit the large wix filter on a stock oil filter adaptor with plenty of room to take it on and off. I wonder how the fit is with Doug's d-port headers.
