Old 05-11-2010, 11:40 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
Default 1966 Pontiac Ventura/Catalina Parts Wanted
WTB for my '66 Ventura:
Set of Rally IIs w/ tires 5x5 bolt circle
Need a Source for front and rear springs
Trans Crossmember Auto
Rear Lower Control Arms (Both)
Pair of Gas Tank Straps
Must be Willing to Ship OR be within reasonable driving distance of Albany NY
Please email: safari421@yahoo.com
Thanks Guys and Gals!
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 05-12-2010, 09:28 AM
stevep's Avatar
stevep stevep is offline
Does you car have a boxed or open frame?
I got my spring from www.espo.com. They seem to have the best deals.
I may have the rear arms.
Old 05-12-2010, 08:59 PM
Good Question Steve, I'll look tomorrow on the frame and get back to you. Thanks!
~Josh
Old 05-12-2010, 10:36 PM
stevep's Avatar
Is your crossmember missing or are the ends just rotted? If the ends are rotted, that is an easy fix.
BTW, I will be parting a 65 Bonneville 4 dr ht real soon.
Old 05-13-2010, 05:17 AM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Hi,
if you parting the 65 ..does it have an usable stock fender antenna..i`m still looking for...thanks Bjoern
Old 05-13-2010, 07:32 AM
stevep's Avatar
Originally Posted by 1965 Pontiac Parisienne View Post
Hi,
I don't think so. I'll look when I get home from vacation.
Old 05-13-2010, 07:42 AM
My car was a victim of a cob job...they must have run into driveshaft allignment issues after "lowering' the car'....the crossmember was cut, welded and relocated to the bottom of the frame...so I believe stating fresh is the best approach. Thanks!
Old 05-13-2010, 11:55 AM
seymog seymog is offline
Default Pontiac rally 5x5 wheels
Hello,I have a set of 4 early style Pontiac rally wheels 5x5 bolt pattern,from a car with no disc brakes,15x6,JY code good condition with 4 marginal trim rings and 2 caps.Selling for $400.00 + shipping from 89431.If interested please contact me direct at seymog@netscape.com,thanks Gary.
Name:	Pontiac 5x5 rims S.JPG
Old 05-13-2010, 05:43 PM
Txbobcat Txbobcat is offline
pm sent to you
Old 05-13-2010, 07:36 PM
Default Frame and Wheels
Steve, Frame is Std and not hvy duty.
Gentleman, could you please give me approximate shipping quotes on the wheels to 12078?
Thanks!
Old 05-13-2010, 09:47 PM
stevep's Avatar
I'll see how good the crossmember is in the 65 when I get back home.
Old 05-14-2010, 04:01 PM
Racer81x's Avatar
Racer81x Racer81x is offline
PM sent
Old 05-14-2010, 09:00 PM
stevep's Avatar
I'm wondering about the crossmember being relocated to the bottom of the frame and if it could be that someone used a trans mount that was too thick?? The correct trans mount is 64-70 big Pontiac only and is very narrow. It also appears that it is crooked when it is properly installed.
Old 06-26-2010, 08:33 PM
tanof tanof is offline
I have a set of control arms and may have the gas tank straps. Email me at tfiegler@yahoo.com if you are still interested.
Old 06-27-2010, 08:16 AM
wrea3_98 wrea3_98 is offline
Default RE FRame
I have a convertible frame and matching auto crossmember, ready to go. Sand blasted and powdercoated chassis black. Out of a 66 Catalina 2+2 convertible 900.00
I may have the rear arms.[/QUOTE]
Old 06-27-2010, 11:41 AM
jdh421's Avatar
jdh421 jdh421 is offline
email sent!
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 10-14-2010, 11:01 PM
Do you still need the lower control arms? tfiegler@yahoo.com
Old 10-23-2010, 01:40 PM
Default RE: 66 Cat parts
I have all the front suspension and the auto crossmember if still interested. Im in Pa.
Old 02-06-2011, 08:38 PM
car is sold...thanks to all that quoted prices....i'll be passing them along.
