rear spring recomendations?
I need to order me some new rear springs for my Can Am(rear sag). Anybody have recomendations on a pair that won't jack the rear too high? I also don't want too harsh of a ride. Here are my options: Moog CC507, Moog 5375, moog 5391, eaton mc1341 std, eaton 1463 hd. Don't know what to get? I have the Edlebrock performer IAS shocks all around. David
1977 Pontiac Can Am, firethorn interior- buckets/console,tilt,tach and a/c, posi and rally II's. I'm the 4th owner, and happy it's mine! I tried to buy my first one in 1986, 20 years later I finally got one! Then Only after a few fun years, needed to sell it. |
Good question as I will need to replace all 4 of my springs. So how about a recommendation for a matching set?
Chris
1971 Trans Am - Sold 1977 Can Am - Sold 2002 Trans Am Firehawk - Sold 2004 GTO - Sold 2006 GTO - Sold 1970 GTO - Sold 1972 Trans Am - Sold 1970 Trans Am - Current Project |
I installed all new springs and shocks in my '73 GTO last year. My goal was to get the car back to original ride height (about 10" front & back from rocker to the ground).
I studied the Moog chart for spring rates, load rates, and installed height. I compared this to factory data with the equipment in my car (A/C, PS, PB, 400 engine, etc.). I picked Moog 578 in the front and 5375 in the back. The front height was perfect, but the back sagged by 1" (9" ride height). I ended up calling Federal Mogel and talked to tech support. The gentleman I talked to recommended using the variable rate CC507 springs in the rear. He used these in his '75 El Camino and said they were perfect for ride height and ride comfort. I ordered a set and it restored the rear ride height to 10". I also installed a new set of AC Delco gas shocks all the way around. I am running BFG P255/60R15 tires on stock 15x7 wheels. Ride and handling is now like a new car. I could not be happier with the results. Here is a picture right after the upgrade last May.
1973 GTO 400 4-spd 1973 LeMans GT |
Thank You for the info . I thought I read somewhere that the CC507 were good..... I could not find it here, and the abodysite is down. I can order my springs ASAP!!
BillyGoat did you use the factory spacers in the front? and what isolator did you use in for the rear?
Thanks, Chris
Just in case anyone looks for this in the future, Eaton spring made the springs for GM for these cars when they were manufactured. The guys there know their stuff even today.
http://www.eatonsprings.com/
. Mark S . Who needs nice and pretty, when you can have mean and nasty? KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs . So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well. >>My 73 Build thread |
Springs
I allso used the Moog CC507 Cargo Coil Variable Rate Coil Springs on the rear with new Energy Suspension Coil Spring Isolators, I got the springs off amazon.com for $68.68 shipped, What a great deal.
I use Edelbrock performer IAS shocks all around and Suspension Techniques 1" Lowering Springs on the front. This gives the Can Am just a slight rake for what I feel makes it look a little bit more aggressive, It allso handles great.
"I never drive faster than I can see !" Stewart |
I did not use any spacer up front. I used the original isolators in the rear.
