Old 06-24-2010, 08:58 PM
GMAN70's Avatar
GMAN70 GMAN70 is offline
Default Help, Rear end ID
Hey Guys,
Can someone please decode these #'s,
Passenger side on the tube:
R 3 B 053 2
Also if it has the square nubs is it an 8.5? I'm confused!!
Thanks,
G
It's better to Burn Out, than Fade Away!!!! Def Leppard
Old 06-24-2010, 10:24 PM
topless lemans topless lemans is offline
im trying to ID mine and can not find it, where is exactly did you find it?
Old 06-25-2010, 12:47 AM
runninwild runninwild is offline
There is usually a two letter code on the drivers side tube right in the middle on the back of the tube looking forward. Find that and go to the Wallace Racing website. They have an online chart.
Old 06-25-2010, 06:25 AM
thadeal4real thadeal4real is offline
post pics
Old 06-25-2010, 07:37 AM
GMAN70's Avatar
These numbers were on the passenger side tube, center facing forward also.
Old 06-25-2010, 05:15 PM
This is off of my '67 axle housing. It is "WD" which according to the axle ID chart is a open rear with 2.93 ratio. That is exactly what it was. It is now a 3.55 posi, but that is another story. It might be different for other years, but the codes for other things seems to be very consistent.
Old 06-25-2010, 05:34 PM
GMAN70's Avatar
Pulled the cover, its got 2:56's, boooo! Here are some pics.
ID:	210041   Click image for larger version
ID:	210042   Click image for larger version
Old 06-26-2010, 06:49 AM
8.2 bop 10bolt or 8.5 pics hard to tell kinda i gotts them bad eyes im going 8.5 what year is it whats it in/out of ?
Old 06-26-2010, 07:28 AM
GMAN70's Avatar
The only numbers I've found are the R 3 B 0 53 2
Old 06-26-2010, 10:44 AM
Kenth's Avatar
Kenth Kenth is offline
8.5", great find if bolted axle shafts. C-clips OK, not as great though...
Old 06-26-2010, 11:21 AM
GMAN70's Avatar
Will it accept 3.23 or 3.55's?
Old 06-26-2010, 03:56 PM
Kenth's Avatar
Those ratios requires a spacer on your carrier, not the hot tip.
I would get a new Eaton posi and the gears iŽd like to make a fine third member.
http://tomsdifferentials.com/catalog.asp?pg=43
Old 06-26-2010, 04:30 PM
Held for Ransom's Avatar
R3 is a GM 8.5", 2.56:1 limited slip originally installed in a 1968-72 Olds A-body. B is the series (should have bolt on axles). 053 day of the year for assembly. 2nd shift.
Old 06-26-2010, 07:17 PM
GMAN70's Avatar
Thanks, Guys, this is the best forum ever!! Looks like I have a 8.5 bolt on axle rear. Yahoo!! Last pics, the last picture is what it will be replacing!
ID:	210115   Click image for larger version
ID:	210116   Click image for larger version
Name:	blown rear 002.jpg
Old 06-30-2010, 10:23 AM
GMAN70's Avatar
Is there a way to figure out what year this rear is?
Old 07-01-2010, 12:19 AM
See if you can see a date code on the webbing of the center section.
Old 07-01-2010, 07:48 AM
GMAN70's Avatar
Thanks, Held.
Old 07-02-2010, 02:53 PM
GMAN70's Avatar
Couple more questions, measures 55 1/2" BP to BP, this came out of an A body? Also there is a "A" on the front of the pumpkin between the upper control arm mounts, what is that?
Thanks,
G
