Has it ever been proven if electric fans work better for all around driving than stock mechanical fans on our classic Pontiacs?
Not really.
On one hand there is the keeping it stock looking. SO if you have to run a mechanical fan, and have a cooling issue, you need to really get all of your ducks in a row for it to work properly. On the other, there is a better selection of drop in and custom fan installs for the electrical route. I have had great luck with the Mark VIII fan install. It was said that they pulled 4000 CFM. But one guy was getting Sick-and-Tired about hearing it and actually tested SPAL dual 11's Vs. The Mark VIII fan. Turns out the Mark VIII fan pulls around 2700CFM. Mine stays at around 190* in 100* heat with Mark VIII. That was with a 7lb cap. I changed to a 13lb. Should see some improvement. ![]() If you are on the fence about which one to use, then I would say do a PRO/CON list. Both can be rather expensive. With the scale leaning heavy on the electrical side of cost.. ![]() Mechanical: Shrouds Fans Spacers Electrical: Fans Hardware Charging system upgrades Relays or controllers HTH, Dave ![]()
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
in my extensive experience, I have not had good luck with electric fans and have not used them now since the 80s. A large 7 blade fan and heavy duty thermal clultch fan with shroud does the job and does it well.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
Do an internet search on"The myth of the electrical fan",an article written about changing a mechanical fan to electrical in a Mazda RX-7,but interesting reading,nonetheless.
I went with electric . One day after washing the car I drove to the store. While I was inside some water got to the relay and shorted out,and caused both of my fans to come on .50 amps each. No need to say I came out to a dead battery, real bummer.I have sense fixed the problem, and haven't had a problem sense. At least a mechanical fan wont kill your battery.
![]() Quote:
I recall a Car Craft article where the engine driven fan consumed something like 12-15hp.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
I read the article. Best part was this quote about the scientific method he made his conclusions: "745W = 62A at 12V. This is obviously already incorrect since it's ridiculous to assume that an electric fan is drawing 62A continuously. But we'll continue anyway."
I love my electric fan !! That being said-I've never had an overheating problem with either of my P-Dude motors even when I ran a mechanical fan. I changed over to electric fan and water pump to eliminate parasitic drag as we like to race our Catalina.
I immediately saw the benefit of an even cooler running motor. The nice thing about electric fans is that they are not dependent upon engine RPM. The fan turns at its own speed whether you are at idle or doing 70mph down the interstate. I see you are here in Florida where we have two seasons HOT and EVEN HOTTER. My car can idle in heavy traffic on the street or in the staging lanes and the temp does not go up because of the low engine RPM - very nice. I have a Flex-a-Lite 180 or 188. Don't remember which it is as I've had the fan in for a few years now without any problems at all, good unit. http://www.summitracing.com/parts/FLX-180/ Thanks, Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
I tried it all, ended up with a factory Pontiac fan, HD clutch, factory shroud. Better then anything...lol
The first time you get stuck when it's hot, you will understand. Switch's, relay's, wires, fuses, have all let me down.
........I'm just learning as I go....... |
Thermoclutch, fan shroud, Pontiac (GM) engineering at it´s best!
Ask Jim Hand.... http://www.dapa.org/building-a-stron...tems/#more-112 and: http://www.grapeaperacing.com/tech/coolingsystems.pdf |
Swapped the electric fan for a mechanical 7 blade, high pitch with SD thermoclutch and all high temp issues went away. I actually think I have a overcooling issue instead. My electric Choke probably gets cooled down to much so it wont let go as it should.....
Reef turqoise -66 GTO Firebird Convertible -68 R.I.P. -73 LeMans 350/350 Barnfind |
So what was the final outcome of the dual spals vs the mark 8?
I completely the agree the real cfm of the mark 8 fans has been exaggerated. I think that the electric fan is a much better choice. It has the same cooling capacity at a stop light as it does at 70. Couple it with an electric water pump and now you reduce heat soak after being turned off. |
![]() Quote:
Remember P = V x I from high school. If you run twin 370W electric fans you will need a total of approx 62A electrical capacity if you run both fans at full power together. That's why you need to make sure your alternator is up to the job. Some of the new fancy OE electric cooling fans use what they call PWM (pulse width modulated) motors. This is where the control system switches the fan/s on for a split second then off and back on continually (we are talking in the order of 200Hz here). By changing the frequency/duration of this switching you control the speed. Not sure if an aftermarket version is available as yet. This sytem also needs special motors as you would burn out the brushes of a normal electric motor. With these, they turn at the speed you need for the cooling amount you need. You still need to electric load protect for flat out running but in most cases they won't need to run flat out increasing electrial system life. |
here is some info i got a couple years ago.dyno's an engine,then runs with several different fans and you can see the difference in power they need to work.some of the mech fans use almost as little power as an electric.
http://forums.maxperformanceinc.com/...d.php?t=583958
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
You do not need a special motor to run a PWM controller.
You are confusing this technology with a stepper motor. Stepper motors are multi-poled motors that respond to voltages that are sent to the motor in a clockwise or counterclockwise rotation. PWM controllers increase the "apparent" efficiency by pulsing the DC source. This helps reduce the spike of electrical current by ramping up the PWM signal. It is very real to expect fans to draw 62 amps; I would bet the initial spike is in excess of a 100 amps or more. |
![]() Quote:
The highest cfm rating for a dual electric fan module I have seen that will fit a Firebird or GTO is 4600. If this system doesn't work, none will.
http://www.summitracing.com/parts/FLX-295/ |
![]() Quote:
I would like to see more documentation to the effect of brushed motors arching under PWM control. News to me. |
![]() Quote:
well i will have some drag results next sunday, will be running without the fan on down the strip, may try it with it on too. It is a race day tho so may not waste a run for that test.right now its 85 today and the car is running 185 down the highway with the fan on. when its 60-65 it doesn't even need to be turned on down the highway.So Far I like the results seems to be cooling as well as the big 18" flex fan was.Just proves that when its cool enough u don't even need a cooling fan running.
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's Last edited by grandville455; 07-18-2010 at 06:05 PM. |
