68 GTO Timing cover
I am looking for a timing cover to fit a 400 pontiac engine. I spung a leak during Hot August Nights in Reno Nevada, once I took it off I found it was eaten away and cannot be repaired. It would be nice to find another one.
Or has anyone had any success installing anything else. All help and advice would be appreciated. |
Dave, what year engine/timing cover do you currently have. I must have 20+ covers. Post your part number (front center) to help determine what you need. Kurt
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
replacing your radiator drain plug with a sacrificial anode will keep that from happening again. my '68 timing cover was trashed from electrolysis, so i went with the 11 bolt swap; glad i did. if you're not trying to stay original, i'd recommend it.
btw, welcome to the site!
John J. |
ive seen the ones that drop in where the cap is, but never a drain plug version.
costs too much |
68 GTO Timing Cover
The part number I am searching for is 9790347.
The anode is a good idea once the new cover is installed I will install one. Thanks for the valueable input/help. |
sacrificial anode: http://www.summitracing.com/parts/FLX-32060/
John J. |
The real problem to pit the cover could be from too fast of coolant passing thru causing cavatation or electrolosys from a bad ground somewhere and the coolant becomes the ground.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
68 GTO timing cover
Just snapped upa replacement cover on E-bay for a reasonable price. Once the new one is installed I am going to install a anode. Thanks for the help and technical advice.
Summit Racing has the anode. |
