Pontiac - Race The next Level |
View Poll Results: What fuel do you run? | |||
Pump Gas | 15 | 30.61% | |
E-85 | 6 | 12.24% | |
C-12 | 10 | 20.41% | |
C-14 | 3 | 6.12% | |
C-16 | 4 | 8.16% | |
C-23 | 2 | 4.08% | |
Alcohol | 9 | 18.37% | |
Voters: 49. You may not vote on this poll |
Post if you are N/A or Power adder.
6.98 @ 199mph 4.53 @ 164mph |
N/A on methanol
none above. power adder VP NO2
N/A on alcohol
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
I knew I miss 1 or 2 it never fails
110 sunoco with 35% ethanol. N/A
68 Firebird Are you running with the wind or breaking it? |
N/A on Methanol.
None of the above. Usually Torco 110, but saw about a 1.5 improvement with VP Fuels Q16.
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
N/A 93 Octane Pump Gas
E-85 N/A
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
N/A on methanol, spare motor on E-85.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
N/A E85
N/A pump gas or E-85 on the spray VP N02
N/A C-14
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Pump gas changing to C-16
C-12 N/A
N/A on E-85...
'66 GTO 3600lbs w/driver, e-heads,474 N/A . best 60' 1.305...best 1/8th ...6.205 @ 110.14...best 1/4 9.794 @ 136.15 through mufflers on e-85 |
93 octane pump gas 15 psi. turbo. water meth injection spraying -20 windshield washer solvent.
N/A pump gas.....running 10.15 at 2300FT in a 3600lb Goat.....will be in the 9's in 11 ...new Coan 5500 stall converter and a cage and mid plate...I can let her go now
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright" |
Why not spray straight meth, much better results. I run a Cooling Mist progressive unit spaying it undiluted in my Grand National. C14 in the Goat.
