need tallist 70 i can get on rear,and smaller narrower deal on front.think 4and a half is correct backspacing on rear but not 100% shure.
rearwill be 235 or 255 70.most likely 7 in wide,not sure of backspce.have no clue on front size.any help would be appreciated.
I have 255/70/15 on the rear mounted on an 8" re-pop Rally 1, and 225/70/15 on the front mounted on 7" re-pop Rally 1.
I have a 1/4" spacer between the drum and wheel on the rear to keep from rubbing the frame. Here's a picture: http://www.cruisintigersgto.com/pics...Bolnius_03.jpg
Plans are what you make when you want to hear God laugh!! |
do you know what the backspacing is?do the fronts have any problem rubbing?thanks.
No rubbing issues on the front.
I'm not sure about the backspacing, but they are the same Rally 1 re-pops available through PY. Maybe they can help or someone else who has them can chime in. I'd measure it for you, but my car is put away for winter. Dan
