Old 01-30-2011, 09:21 PM
chief455's Avatar
chief455 chief455 is offline
Default 1977 Trans Am 400 XA engine - just rebuilt
1977 Trans Am 400 engine
Code XA Date = D287
6X - 4 heads Date = C287
Bored .030, boiled, all new freeze plugs, crank cut 10/10 and polished, new cam bearings.
Rods stock, new TRW flat tops. New high pressure oil pump, pick up tube tack welded on.
Clevite bearings, double roller timing chain set, rebuilt heads with valve job.
New Comp 272 cam, lifters and dual springs with adjustable rocker arms.
I bought the engine already rebuilt for a project that has been sold.
It was an unpaid machine shop deal with another motor, so no receipt came with it.
I checked inside the oil pan and removed one head to verify and take a few pictures.
Then assembled and started on test stand with special break in oil.
It has run over an hour before the video was made today.
This was a 30 degree cold start and warm up.
Everything is good to go.
You get the long block oil pan to intake:
NOT INCLUDED:
carb
exhaust manifolds
flywheel
distributor
pulleys, brackets, alt or starter
Asking $1600 and you know a machine shop bill and the new parts cost double that.
Local pick up is best
Can ship at buyers expense.
860-379-2688 if you are ready to buy a rebuilt 400 for $1600 and have questions.
CLICK ON IMAGE TO PLAY VIDEO VVVVV
Old 02-02-2011, 08:25 PM
chief455's Avatar
want this gone - if you need a fresh 400 ready to drop in - make an offer!
Old 02-07-2011, 08:51 PM
chief455's Avatar
$1000 cash - come hear it and take it away. No shipping for this price.
860-379-2688
Old 02-07-2011, 09:01 PM
sinister76ta's Avatar
sinister76ta sinister76ta is offline
If I was closer, I'd snap that up for that price.
Hoarder of various 73-77 Firebirds and Trans Ams
Old 02-08-2011, 07:43 PM
chief455's Avatar
Thanks.
Got a comment about the video - running lean, pop through carb, puff of smoke at the end.
YES - the motor has been broken in for about an hour, but not tuned in - it's been too cold!
It had sat on that stand about 2 weeks before we made that video on a 30 degree day.
It has a Q-jet with no choke - so, yup, it popped and coughed a little while warming up to ~ 140 degrees.
And some hot oil puffed through the valve cover hole when shut off. Even some paint burning still. It all seems pretty normal to me. Sure - you will want to do things to it for your car - but the long block is ready to drop in. Tins, pumps, distributors, carbs - if you can't swap those or torque bolts and adjust rocker arms maybe you shouldn't be buying a motor
I don't get it - buy a rebuilt motor never started or seeing inside it - or one that has proven to run good with oil pressure and compression and not rapping - for a grand!!
Used 400's are near that much....anybody need an engine?
Old 02-08-2011, 07:51 PM
I do need a 400, that's why location suck. Good luck with the sale, it's a steal.
Old 02-08-2011, 08:14 PM
70UglyBird 70UglyBird is offline
Yes that is a KILLER deal, wish I was closer too. GL with the sale!
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
Old 02-08-2011, 08:23 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
pm sent
Old 02-08-2011, 09:49 PM
chief455's Avatar
Originally Posted by ITSBACK View Post
pm sent
replied - thanks!
I understand a buyer being cautious about an engine with no gaurantee or they did not build themself. I bought this long block before it was ever started for $1300 and had it shipped to me. At that price I felt it was worth the risk.
Then all the work getting it running. Now I can say it does run, and seems fine.
I feel at this price, knowing just the specs, pictures and the video clip - you just can't go wrong.
Old 02-12-2011, 08:15 PM
chief455's Avatar
SOLD
thank you
