Adjusting Camber on a '64 GTO
I'm getting some wear on the outer edges of my right front tire and the camber is visibly off. My question is, do I add or remove shims at the upper pivot shaft bolts?
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield ------------------------------ 2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior 1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top |
Depends on if the wear is on the outer edge or inner edge of the tread. If you have too much positive camber (causing wear to the outside edge of the tire) you would need to add shims to pull the upper control arm shaft towards the engine. The opposite for negative camber. Usually the suspensions need more positive camber and folks just run out of shims to remove ... can't get the camber to positive. If that happens you can install an offset control arm shaft that will move the camber towards positive. Hope that helps.
