Seeing the pic of the brake-levered '61 reminds me of something I wanted to share...
You can add a gauge to your dash similar to what's shown in the pic but instead of drilling a hole in the dash, use the ash tray door instead. Remove the ash tray bin, punch the 2-ish inch hole in it and voila! A gauge in the dash without the commitment of doing so in the main (welded in) dash panel. |
Matt,
I didn't know you played the viola! Yer pretty smart. Darn good idea. ![]() |
Not a bad idea, and it can be reversed if desired by simply putting in another ashtray cover. I suppose you could be really stealthy and mount the gauge inside the ashtray, then open it up when you're driving and close it when you're parked.
I actually kind of like the idea of putting gauges in the dash like that - I've seen it on several cars over the years - but I could never bring myself to cut the holes. |
I'd have a real hard time drilling holes in my dash too, but the ash tray thing is not a bad idea. Thanks, Matt.
Alan |
Thanks for the replies, guys...
Stuart, I mocked up the peek-a-boo, in-the-ashtray idea...on '62s anyway I found it hard to read the gauge, certainly harder than the facing-out approach. And just to geek out a little more, you could add more gauges to a spare glove box door, but they start getting too far away at that point (IMO). |
Great idea... Looking at my '58 ashtray, that might be an idea to consider.
And I must have missed the original post on that picture... Is it a hand brake as opposed to the heel-toe method?
Thad 1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver 1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!! |
![]() Quote:
>DOLP!< (gag reflex sound) ...actually I don't mind A-pillar gauges (well, OK, I don't need neon-surrounds and carbon fiber pillar trim) if they are mounted for business.
To that end, I have seen the parent of that look on a '61 where the '62 tach / cup was anchored to the inner A-pillar trim with the tach wires run behind the trim... |
I added gauges to my '64 GP ashtray. Works great and hides them when closed...
Excellent!
