Still running hot over 3000rpm
I flushed the cooling system and I bought a new 4 core Harrison look a like radiator from our host. The temperature still climbs to almost 230 degrees when I run on the highway above 3000 rpm.(3.90 rear,4 sp.). I have the stock water pump also.
What can I try next? Thanks, Dave |
Where is your jetting? timing ?
Fan set-up?
Pump clearance? Top gear ratio? Compression ratio? Fuel octane? Straight gas or ethanol? Crank pulley and water pump pulley diameters? Rear tire size? Ambient temperature? T-Stat temperature? Spring in lower rad hose? Top rad hose smooth or ribbed? Water Wetter? Rad cap pressure? Over flow catch can? Auto trans cooler in radiator? Headers or manifolds? (adds to under hood temps) Is your E-Brake adjusted?
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
x2 on that entire list . I think with your rear end gears that may be causing your problem. 390's at sustained highway speeds will tax any cooling system. 230 plus degrees is kinda high so I would look at some other areas mentioned above
Dave, go to a lower rear ratio. You don't race do you, so why need 3.90s? 3000 rpms with 390 gears out on the highway will make it heat in a big way.
The gears are not the cause of the over heating for gods sake, Hell Pontiac sold cars with 4.33 gears that could cruse at highway speeds all day long!
What is your total timing at, and do you have at least 10 degrees of vacume advance on tap? At highway speeds the only things that will make for overheating are 1) timing, 2)Jetting, 3)restricted water flow, or 4) a fan set up that moves tons of air at idle but blocks the needed air flow when traveling down the road.
steve, your wrong and your right, 390' and up gears will cause overheating and especially on the highway. dont know what your thinking there but even the literature written back in the day comented, not complained, but commented that engine temps creaped up 'There" at highway speeds. so with that gearing it was a common problem.back then. hence all the extra cooling capacity that went olong with special order gear sets. and racing packages.
390 and up gear sets were for quarter mile drag racing ,maybe 11-18 seconds at a time. Not driving from Kansas to Nevada at 90 MPH or 16 hour road trips.Those kinds of cars were trailered or operated at much more sensible engine speed on high way or road trips. but your right that other contributory factors should be looked at. You cant put a set of 433 gears ina car and not look at other demands it plces on the car. |
pump plate clearance, Fuel ratio, timing, and T stat should be at 160 for sure in this application. maybe even run one heat rating colder spark plug
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
I was always under the impression that alcohol in fuel reduced combustion amd engine temps.
I had a 68 firebird for a while with 4.33 gears and a 4 sp behind a worked over high comp(10.7 to 1 iron heads) 400 cid, and on the highway at 60 mph it never topped 200 degree`s with a 3 row radiator.
yea, actualy when I think of sustained hiway speeds with a 433 rear i'm thinkin about 60 mph's. but out here anything less than 80 mph stays to the right...by law.
so actualy your right. |
Cam : lunati, 230 dur., 460 lift , For fuel : I run 5 gals of 93 Sunoco mixed with 1 gal of leaded Sunoco 112 octane. Timing : 11 degrees idle , 34 degrees all in. T-stat : 180 Jetting : 68 in center, 70,s in ends Plugs : AC Delco 45s Manifolds : Stock Hoses : smooth w/ spring in bottom hose. Cap ; 15lb Pullys : stock Rear : 3.90 How would I be able to tell if the fan is restricting air at highway speeds?? Would running cooler plugs, like 44s, help ?? Would a 160 t-stat help?? Thanks everyone.......I still learning |
Stock mechanical fan or electric? Shroud or no shroud?
Bryan |
160 t-stat? Not really. Remember, they came with 190 or 195s from the factory. I say 180 is the lowest to use so moisture doesn't accumulate in the engine. There's a guy here I was talking to last week that said he's not running a thermostat. He's using a restrictor instead and his temps stay at 180 with it. I've no idea what size it is. All he said was to experiment with the hole size to get the temp you want. Must be some kind of waher with a certain hole size in it for coolant flow. Sounds good but I'm very leary of going that route. What is your mix of antifreeze to water Dave? I've been told that in the hotter areas like ours and down south to run 30% to 70% water with Water Wetter added. It's helped my temps come down, along with everything else I've done.
How are the temps at idle? Does it sit right at t-stat or just above? Might need that A/C kit with the flaps to cover the area around the rad. Air might be going AROUND the rad instead of through it.
Drive it at 2500 rpm down the highway and see if it overheats. At over 3000 rpm, you are generating a lot more heat that has to be gotten rid of...simple physics. The stiff gear may not be the entire problem, but it's a big contributor, IMO. Put a 3.23 in it and enjoy the good gas mileage, better traction, and reduced engine wear...(as well as being able to cruise at 70mph!)
Jeff |
Highway speeds back in the 60s were still at 50/55 and maybe 60 tops on the Interstates that were around. So sure 4.33 gears wouldn't be much of a problem back then. But for today, any speed seems to be fair game locally and out on the Interstates. 70 to 80mph with 4.33s is gonna make the engine run a lot hotter than it would back in the 60s, especially with the crap we have now for gas.
10% alcohol runs, burns hotter but is way less dense than regular gasoline. It makes cars run even leaner. Also,Since your car is working harder to reach the same goal, you get more heat.. The epa ratings with e85 will tell you this on window stickers on brand new cars and trucks.
