Old 07-25-2011, 02:39 PM
zoso zoso is offline
Default engine shudder/shake
engine has a shudder/shake to it.it seems like when it gets to a certain cylinder it moves the block on the mounts.
i dont think its a miss.i verified all cylinders are firing with a timing light.i checked the plugs and they all look textbook good accept #4 cylinder.it looks leaner than the rest.im thinking the valves of #4 are too tight.Am i on the right track???if i am how do i adjust only #4??
78 400
standard bore
2801/1.52 rkrs
holley650 dp,4777
16 steady vac guage
runs good/strong
18initial/36 total....msd6...msd dist no vac adv. black 18 bushing/medium silver springs
thank you
Old 07-25-2011, 08:09 PM
steve25 steve25 is offline
If its not back firing thru the carb, then if its due to a too tight valve it will be the exh on #4.
Try this, idle the motor as low as you can.
Pull off the valve cover on that side and tare off an long and tall enough strip of card board to slip down in between the valve springs and the valve cover ridge on the exh side of the head so that when the motor runs you get oil on the exh and have a fire.
Next back off on the stock jam nut for #4 exh, you will hear a clicking and at that point if the valve was too tight your shudder should be gone. If so torque down the nut to 20 ft lbs and call it a day!
Old 07-25-2011, 08:40 PM
geeteeohguy's Avatar
You can also hook up a vacuum gauge and disconnect the coil wire and crank the engine. If you have a big sweep of the needle when the engine comes around full circle instead of steady vacuum, you have a dead cylinder (compression). You can also do this test by ear if you're experienced. The engine will crank over with an uneven sound as it speeds up when the low compression/no compression cylinder comes up on compression stroke. If it's a tight valve, as posted above, it's an easy fix, usually.
Jeff
Old 07-25-2011, 09:18 PM
BKB's Avatar
BKB BKB is offline
I had an issue like yours a few weeks back. It turned out to be a broken rocker stud. Hope that's not your issue.
Old 07-25-2011, 10:10 PM
i have poly locks ...is it the same deal...tighten till the tap goes away...also i have the bbc rocker studs. maybe its loose???the motor doesnt tap at all.#4 triggers the timing light.and i can shift at 5250 youd think it would come apart if something was loose or broken
Old 07-25-2011, 10:41 PM
BKB's Avatar
BKB BKB is offline
My big block rocker broke because they were installed incorrectly. It broke idling in the driveway and had a serious miss. I shut it off & pulled the valve cover & discovered the broken rocker.
