THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Closed Thread |
Ford to recall 1.1 million pickups for gas tank problem
08/01/11 - TRAVERSE CITY, Mich. (AP) -- Ford Motor Co. is recalling 1.1 million pickup trucks because the gas tanks can fall off and cause fires.
The National Highway Traffic Safety Administration said Monday on its website that the metal straps holding the tanks can rust, allowing them to fall, rupture and catch fire. The defect has been blamed for eight fires, three of which spread to the rest of the truck. One person was injured, suffering first- and second-degree burns, Ford spokesman Wes Sherwood said. The recall affects certain 1997 through 2004 Ford F-150 models, as well as some 1997 through 1999 model year F-250 pickups. Also affected are Lincoln Blackwood pickups from the 2002 and 2003 model years. They were sold in cold-weather states where salt is used to clear roads. The salt corroded straps holding the tanks and they broke, NHTSA said. Sherwood said the company will notify owners in September to bring their trucks to dealers who will replace the straps with new ones that are coated to resist corrosion. Parts to fix the problem, he said, won't be widely available until then. People with questions should contact their dealer, who can install a cable to hold the tanks in place until the replacement straps arrive, Sherwood said.
1959-1980 Pontiac Window Sticker Reproductions : http://www.pontiacwindowstickers.com My Bio: I am currently writing articles for POCI's Smoke Signals magazine and enjoy promoting and discussing the history of the Pontiac Motor Division. |
http://www.youtube.com/watch?v=e4QgWRycd7I
The top of the line in utility sport. Unexplained fires are a matter for the courts...
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry! - Mike 1967 GTO Last edited by Qball; 08-01-2011 at 05:29 PM. |
Try washing the undercarriage once in a while.
Why is he not suspended? |
Gee, Ford saved a few pennies by not plating those straps. Good call.
Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race. ― Calvin Coolidge |
You're kidding, right?
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
You don't?? You need to get the salt off and most automatic car washes(unless you get the most expensive wash) don't wash the undercarriage. salt eats away at everything under the car/truck.
X2!!!
God forbid if people took care of their stuff. Granted,Ford uses some crappy metal.IE,diff covers and oil pans;we change those quite often here at the shop.But if you hosed things off,the stuff will last longer. My truck is an `03,and the diff covers,oil pan,AND tank straps are in great shape.Why?cause it goes to the car wash after EVERY snowstorm. Imagine that. I just love lazy people and the way they blame everyone else.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
I can understand salt up north but if it is happening all over and it is a metallurgical issue, wouldn't "washing it off" make it worse? I personally DO wash the the undercarriage each week at the car wash just to keep it clean as i have a dirt drive (glad Scott Misus isn't around to bust me on that one)
I still have a stack of straps from the last time this happened with a different model when I was working at the Ford dealership. Can't remember which model though. Maybe the contour? Focus? I'm still trying to block it out...
At least it's not a cheap bolt head that could pierce a gas tank upon rear impact.
The joker in the deck keeps sending me his card. Smiling friendly, he takes me in. Then breaks my back in a game I can't win. |
So now salt on the roads(put there intentionally) is now the responsibility of the manufacturer.
Following that liberal logic,why don't all the Ford owners that live in close proximity to the ocean have Ford replace things that corrode on the vehicle as a result of ocean air? |
I've already had the straps off my 04 F150 to replace the fuel pump, they looked good
1 1/2 years ago. It was built in august 2004.
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
Isn't the tank plastic? If it's metal, how long do you have to drag the tank down the road to wear a hole in it and start a fire?
I have a 79 Trans Am that was originally sold in Denver CO. In the 70s through the 90s they used nothing but salt on the roads and my straps on the gas tank have not fallen off. Cmon trying to blame people instead of Ford is a stretch. I had a 85 Bronco and the rear had a small hole of rust and the next year the rust took over the rear wheel well. How many people have old cars with the original straps attached????
going bandit-Reynolds style |
A Friend of mine let his wife drive his 64 GTO (unrestored) to college every day in Michigan. One day he tells me that he has to go and get her and tow the car back home with a tow strap after the gas tank straps rotted through and the gas tank falls on the ground shearing the rubber gas line.
Chit can happen on any vehicle in Michigan (salt) weather. I changed the frame on my 64 GTO due to salt damage and I routinely washed under the car to TRY and get the salt off the undercarriage during the time the car was in Michigan. Yep, I totally agree that the Ford "GAS TANK STRAP GUY" should be hung up by his B*LLS for not testing the vehicle in Michigan SALT conditions over several years before he signed off on the vehicle. I realize that none of you guys ever made a mistake. Reality is the guy was probably laid off by Ford several years ago before GM and Chrysler went bankrupt. Tom Vaught ps Here is a list of recent GM Recalls: • Chevrolet Astro Recalls • Chevrolet Avalanche Recalls • Chevrolet Aveo Recalls • Chevrolet Bel Air Recalls • Chevrolet Beretta Recalls • Chevrolet Biscayne Recalls • Chevrolet Blazer Recalls • Chevrolet Brookwood Recalls • Chevrolet C10 Recalls • Chevrolet C10 Pickup Recalls • Chevrolet C10 Suburban Recalls • Chevrolet C1500 Recalls • Chevrolet C20 Recalls • Chevrolet C20 Pickup Recalls • Chevrolet C20 Suburban Recalls • Chevrolet C2500 Recalls • Chevrolet C30 Recalls • Chevrolet C30 Pickup Recalls • Chevrolet C3500 Recalls • Chevrolet Camaro Recalls • Chevrolet Caprice Recalls • Chevrolet Cavalier Recalls • Chevrolet Celebrity Recalls • Chevrolet Chevelle Recalls • Chevrolet Chevette Recalls • Chevrolet Chevy II Recalls • Chevrolet Citation Recalls • Chevrolet Cobalt Recalls • Chevrolet Colorado Recalls • Chevrolet Corsica Recalls • Chevrolet Corvair Recalls • Chevrolet Corvette Recalls • Chevrolet Cruze Recalls • Chevrolet El Camino Recalls • Chevrolet Equinox Recalls • Chevrolet Express Recalls • Chevrolet G10 Recalls • Chevrolet G10 Van Recalls • Chevrolet G1500 Recalls • Chevrolet G20 Recalls • Chevrolet G20 Van Recalls • Chevrolet G2500 Recalls • Chevrolet G30 Recalls • Chevrolet G30 Van Recalls • Chevrolet G3500 Recalls • Chevrolet HHR Recalls • Chevrolet Impala Recalls • Chevrolet K10 Recalls • Chevrolet K10 Pickup Recalls • Chevrolet K10 Suburban Recalls • Chevrolet K1500 Recalls • Chevrolet K20 Recalls • Chevrolet K20 Pickup Recalls • Chevrolet K20 Suburban Recalls • Chevrolet K2500 Recalls • Chevrolet K30 Recalls • Chevrolet K30 Pickup Recalls • Chevrolet K3500 Recalls • Chevrolet Kingswood Recalls • Chevrolet Laguna Recalls • Chevrolet Lumina Recalls • Chevrolet LUV Pickup Recalls • Chevrolet Malibu Recalls • Chevrolet Monte Carlo Recalls • Chevrolet Monza Recalls • Chevrolet Nova Recalls • Chevrolet P10 Series Recalls • Chevrolet P10 Van Recalls • Chevrolet P20 Recalls • Chevrolet P20 Series Recalls • Chevrolet P20 Van Recalls • Chevrolet P30 Recalls • Chevrolet P30 Series Recalls • Chevrolet P30 Van Recalls • Chevrolet Prizm Recalls • Chevrolet S10 Recalls • Chevrolet Silverado Recalls • Chevrolet Spectrum Recalls • Chevrolet SSR Recalls • Chevrolet Suburban Recalls • Chevrolet T10 Recalls • Chevrolet Tahoe Recalls • Chevrolet Townsman Recalls • Chevrolet Trailblazer Recalls • Chevrolet Traverse Recalls • Chevrolet Uplander Recalls • Chevrolet Vega Recalls • Chevrolet Venture Recalls http://www.autorecalls.us/aut-01/rec...let/index.html
Like i asked before, How long do you have to drag the tank down the road to wear a hole in the tank and start a fire?
Could you please give us YOUR definition of "recent"? It's been a few decades since Chevy built a Bel Air, Biscayne or Brookwood, and that's just the models that start with "B" in your list above. The Vega (also on your list) is more "recent" than those three.... I'd go into the "C's", but there are just too many that are decades old in that list... |
Closed Thread |
