Old 11-05-2011, 09:29 AM
Poncho Walt Poncho Walt is offline
Question 71 T/A Shaker Ground Strap and Engine Grounds
I have searched this forum on this subject and found some info on. I have seen that there is a strap that connects from the rear bottom of the shaker to where? I think its somewhere on the firewall. What type of connection is used on the firewall? And where can I buy the parts I need to make the shaker work properly? If anybody has pics of the strap in use on the car would be fantastic. Also, I would like to replace all of the ground straps under the hood. Where are they all connected? Pictures always work great. Thanks,Walt.
Even a blind squirrel eventually finds his nut's
Old 11-05-2011, 07:04 PM
FunctionalShaker FunctionalShaker is offline
The clip for the shaker ground wire is attached to the firewall under the same bolt/screw that holds the wire harness clip -- upper center of firewall face. Your engine ground harness should attach to the firewall below and to the left almost directly behind the valve cover.
This is how it is on 70 cars. I imagine it's the same for yours.
Old 11-05-2011, 08:12 PM
Default Shaker
The phone number for the guy who make the functional shaker parts is 512-789-3005 or you can reach him by pontiacplus@suddenlink.net
Old 11-05-2011, 09:25 PM
Norwood's Avatar
Norwood Norwood is offline
He makes conversion kits, not reproduction of original parts. Only one guy makes those and it aint him.
The Following User Says Thank You to Norwood For This Useful Post:
Old 11-06-2011, 06:12 AM
tommie69's Avatar
tommie69 tommie69 is offline
Wink
I wonder who it could be?
First picture is the clip on the firewall were the graund wire goes for the shaker!
second picture is the ground wire on the shaker,its about 7" long.
third picture is the ground wire on the back of the pass side head to the firewall,that wire is about 8.5" long.
my car is a 72 not a 71 maybe the same?
ID:	262404   Click image for larger version
ID:	262405   Click image for larger version
Old 11-06-2011, 10:22 AM
Cool
Thanks for the pics Tommie. Any idea where I could get a female spade mount like you showed in the pic? Also, I could not make out what type bolt is used to mount the ground strap to the bottom of the shaker. I would like to also see some pics from some other members especially for the 71 T/A. Any other grounds other than the one on the firewall? Thanks, Walt.
Old 11-06-2011, 10:46 AM
Norwood's Avatar
Great Pics Tommie....
Old 11-07-2011, 06:05 PM
tommie69's Avatar
No problem Walt.
I don't know where you can get those stlye clips from,but they don't look like they would be to hard to find?Itook a look at the bolt on the shaker and it looks just like the bolt on the firewall that holds the clip on.If you need any more pictures just let me know.Tom
Old 11-07-2011, 07:13 PM
Smile
Thanks for the offer Tommie, The one pic is a little fuzzy and the one with the clip is a bit dark. If you could resend the pics and maybe some other members will chime in on the subject with some photos of their own.
Old 11-08-2011, 07:32 PM
tommie69's Avatar
Here hope this helps!
last picture is the shaker ground wire.
ID:	262823   Click image for larger version
ID:	262824   Click image for larger version
Old 11-10-2011, 09:52 AM
Todd Mullin Todd Mullin is offline
Walt if you find these parts will you post where you get them from. I need them too.
Old 02-28-2018, 06:18 PM
njsteve's Avatar
njsteve njsteve is offline
Has anyone found a source for the firewall female spade connector that the ground strap clips to? I need one for the gramma car.
Old 02-28-2018, 07:43 PM
weranc55's Avatar
weranc55 weranc55 is offline
I need a couple to. I looked up with amk and asked M and H. No luck
Old 02-28-2018, 07:54 PM
njsteve's Avatar
It's a weird little thing that NORWOOD should be making! It's a prefect candidate since it's a little metal tab dohicky that no one else makes...and everyone with a 70 to 72 needs one.
Norwood you listening???
Old 02-28-2018, 08:08 PM
Norwood's Avatar
Not an easy one to make. I’m pretty sure that it is a generic GM part that was used for many applications. This is the best pick I have handy I will get and post a better one tomorrow
Old 02-28-2018, 08:29 PM
njsteve's Avatar
Here's the parts breakdown.
Unfortunately item #46 "Terminal - adapter to ground strap" says "N.S." (not serviced)
Name:	shaker parts.jpg
ID:	476863   Click image for larger version
Name:	shaker parts list.jpg
Old 02-28-2018, 08:56 PM
Held for Ransom's Avatar
PN was 8900232. I don't know of a source.
So long, farewell.
Old 02-28-2018, 10:14 PM
Norwood's Avatar
Other than the million of them that must be in junk yards across America
Old 03-01-2018, 04:16 PM
Norwood's Avatar
Shaker ground clip
Old 03-01-2018, 06:44 PM
weranc55's Avatar
Shaker ground clip
Yup that’s what we need. Is it one or two per car?
