OHC-6 TECH Over Head Cam projects, questions and advice.
Old 11-13-2011, 05:21 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Default Brewin' up a Tempest 1968 Hot Rod OHC article
This was taken from a 1968 "Complete book of Engines" from the editors of Hot Rod magazine. Now there is a OHC section I thought it belonged here. Stroked OHC with a Chevy 250 crank and Algon injection , Enjoy! You'll probably need to right click and open up into new window to view fullsize.
ID:	263350   Click image for larger version
ID:	263351   Click image for larger version
ID:	263352   Click image for larger version
ID:	263353   Click image for larger version
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 11-13-2011, 05:22 PM
more
ID:	263355   Click image for larger version
ID:	263356   Click image for larger version
6.27@107
9.97@131
Old 11-13-2011, 06:00 PM
Jeff Hamlin's Avatar
Thumbs up EXPLORER SCOUT POST #14...
OHC POWERED ALTERED DRAGSTER PROJECT.
HOTROD MAG, 3 part artical. part 1 was Jan 67' then Mar, & finaly May for part 3.
sadly never to be heard about again
The engine was a doner from HURST.
Most likely the engine that was fitted into the Car & Driver/HURST OHC POWERED JAGUAR XK-E Project. CAR & DRIVER JULY 1966.
GOOD STUFF!
Old 11-13-2011, 06:59 PM
Cammer-6 Cammer-6 is offline
Bill,thanks for posting that
any chance of getting some full size hi res scans suitable for emailing?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 11-13-2011, 07:37 PM
Thumbs up
Agreed good artical.
Gary,
Keep an eye on epay.
It comes up now & then.
My copy is put away somewhere.
Old 11-13-2011, 08:10 PM
No problem, pm your e-mail. I figured they would be too big too post in original size.
Oops on my part it was the 67 Book of Engines, here's the cover
6.27@107
9.97@131
Old 11-13-2011, 09:37 PM
will do
Thanks Bill
Old 12-22-2011, 10:32 AM
Half-Inch Stud's Avatar
Here's a couple photos, and the link to a downloadable OHC6 article pdf by Jim Black:
http://www.overheadcammerschapter.15...stic%20Six.pdf
Name:	OHC6 Block.jpg
ID:	267852   Click image for larger version
Name:	OHC6 phantom view.jpg
Old 12-23-2011, 08:07 AM
I love the Picture showing the Magneto, and notice that they must use a second accessory drive as an upper bearing!!!!! Or is that a dry Sump oiling system, and are they using the second oil pump in that system? And then would the front normally driven sprocket just rotate at Engine Speed? Interesting.
Last edited by camerjeff; 12-23-2011 at 08:11 AM. Reason: Still can't spell in the AM either.
