Old 11-28-2011, 07:34 PM
gopogo's Avatar
gopogo gopogo is offline
Default Brakes won't bleed
1968 Firebird. I had a master cylinder with a slight leak running down the booster. Bought a Raybestos replacement. Bench bled it and installed. Now I can't get the air of the brakes system. Every pump shoots 1/2 air and 1/2 fluid on every wheel. I am using speed bleeders with the check valve and sealant on the threads. I have pumped gallons of fluid through the system. What am I doing wrong?
Old 11-28-2011, 08:03 PM
69FIREBIRD76MM's Avatar
U PROBANLY HAVE AN AIR LEAK SOME WHERE, HAD THE SAME PROBLEM WITH A 67 BIRD...IT WAS A LEAK. FIX IT AND BLED THE BRAKES AFTER FINE
Old 11-28-2011, 08:29 PM
Sirrotica's Avatar
I agree your sucking air into the system somewhere, could even be a bad new part sucking air past the seals on the spool. If it's a reman it's even a better chance that it's defective.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-30-2011, 01:54 AM
screw speed bleeders - try this:
Harbor Fright has them for 25 bucks. Hook up your compressor, have your kid watch the master fluid level and let fly. I have an extra bleeder hollowed out for use with this so no air is sucked around the threads.
Old 11-30-2011, 11:40 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I can tell you when I bench bleed my Strange MC it took forever to get all the air out of it. I thought I had it all out then 3 more pumps and it would have some mor ecome out.
Skip Fix
Old 11-30-2011, 11:49 AM
KenM's Avatar
KenM KenM is offline
Make sure when you bleed you're not running the master cylinder too low and sucking air. Someone should be with you keeping an eye on it and adding more fluid as the brakes are pumped. Sounds obvious, but only after it happens to you.
Ken Mild
69 GS400; 462ci; 430hp, 530lb.ft.
12.90 @108.45mph - Open diff. / 3.08 / BFG T/A's
http://www.youtube.com/watch?v=9JjGIo3V40E
Lover of ALL Muscle Cars
My other life is spent on www.V8Buick.com
Old 12-01-2011, 08:32 AM
gopogo's Avatar
Thanks for all the tips. Ordered a new master cylinder with fingers crossed. Looks like a trip to Harbor Freight this weekend.
Old 12-01-2011, 09:12 AM
Sirrotica's Avatar
You can make a trip to harbor freight if you want, but gravity will have the job done in no time at all and you don't need 2 people to do it. Over 40 years of twisting wrenches and I have never used any bleeding aids other than gravity and if another person was available I sometimes have had them pump a system, usually I used gravity bleeding almost exclusively. You can decide for yourself, but old fashioned physics works as well as any fancy bleeding equipment.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 12-01-2011, 09:58 AM
F ROCK's Avatar
F ROCK F ROCK is offline
Brad; describe you're gravity technique, as i'm always doing this alone.
i have an old mighty vac, that is a manual pump that you pump under the car; i use that but gravity sounds good; i can do something else while i'm waiting.
do you just leave the bleeder open, w/ a pan under it?
or do you close the bleeders and let the bubbles rise?
Old 12-01-2011, 10:09 AM
Old Goat 67's Avatar
I rate this technique above ALL others.
http://arkansaspontiacs.org/techstor...37;20story.htm
Have used my homemade one for close to 25-30 years. When no other method worked, this one always did, because of the low pressure softly "pushing" the bubbles from the high spots in the lines, I surmise. Below is mine, I hook it up to the compressed air in the shop through a regulator set at 15 PSI.
I don't have the problem of leaking fluid with mine like this guy had. All I do is bleed one wheel at a time, check the level of the master before doing the next wheel. Ten to fifteen minutes and I'm done. Of course, bench bleeding the master is a prerequisite.
Charles
ID:	265455   Click image for larger version
Old 12-01-2011, 10:12 AM
Sirrotica's Avatar
It's fairly easy, just open the bleeders and let them feed fluid until there is no air coming out the screws. I tighten them and let the system set about a minute or two and just re-open them to make sure all the air is out and no bubbles are coming through, tighten them up and your done. Also sometimes I just bump the brake pedal just barely stroking it maybe an inch at the top of the travel to get the siphon started but most systems will start just by filling the reservoir.
If you still do not have a pedal that is firm bumping the pedal while watching for bubbles coming up in the reservoir will tell you if there is any air left. Frequently just bumping the master cylinder will float out anything that could still remain.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
