OHC-6 TECH Over Head Cam projects, questions and advice.
Old 12-11-2011, 04:22 PM
ksgto ksgto is offline
Default OHC-6
I have an OHC-6 w/ a 4barrell carb would this be the 250. Where are the numbers at to find out which one it is. Also the front timing belt cover is broken can this be welded. Any info would be great. Thanks Bob
Old 12-11-2011, 04:44 PM
Jeff Hamlin's Avatar
Default 230 &/OR 250
Carb could be either.
Most will have the Alum; disc with a Pt#
Some may have it stamped on the body.
You asked if the Belt cover can be welded, Is it a Metal part?
If it is the Alum, belt cover that is 66' Only and is a cast part.
Old 12-11-2011, 09:48 PM
Cammer-6 Cammer-6 is offline
[QUOTE.
If it is the Alum, belt cover that is 66' Only and is a cast part.[/QUOTE]
and very early 67
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
