I build custom turbo kits on anything with 4 wheels. I have always wanted to turbocharge a OHC 6. The open engine bay would lend itself very nicely for turbo mounting, piping, routing, etc. I am thinking a drawthru turbo kit from a 301 would be perfect. Anybody interested? I have four turbocharged Pontiacs myself. My '96 Bonneville 3.8L V-6 made 500whp on 20psi. The OHC engine I'm sure breathes better and should react equally as well. A stock low comp OHC would not need any mods at all.
Jeff Ianitello |
i have a ohc 6 sprint that came out of my 67 lemans and i always wanted to turbo it too just worried how much it would take. if i remember correctly the sprint engines had like 10.75 - 1 compression so it would need pistons to drop the compression down.
-Rob 67 LE MANS in pieces... 68 gto 84 grand prix twin turbo 496 pontiac 25.3 cage |
Jeff
I have a 67 230 cu in OHC 6 which originally was the lower compression (9.0:1) 1 bbl version that I have added the 4 bbl "Sprint" intake/exhaust manifolds to. I am going to transplant it into my 67 Lemans in place of the original 326 V8. I chose the the 1 bbl version so I could run 93 octane pump gas. What would it take to reliably turbo this motor for the street? It currently has a Borg Warner WC T5 mated to a 10 bolt 3.23 posi. It would be great to see what this 6 could do performance wise, but I'm totally lost when it comes to adding new technology to old motors. Let me know if I can help. Thanks Ron
Another Red Light Nightmare ![]() 1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw ![]() 1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project. Semper Fi |
Jeff, had the same idea for some time now. i have all the parts sitting, just need time to put them together.
Jon Peters 66 tempest 3880 lbs with driver 455 .40 over, 6x, XE274H cam, th350,9 inch 3.89, 275/50/15 mt dr 13.04 et / 102.51 mph 11.97 et/ 113.68 mph w/150shot 75 Astre Turbocharged OHC 6, TH350 1/8 mile stats 8.4813 ET / 82.07 MPH |
You don't want the sprint head because the compression.
I'm in the process of setting up an EFI turbo engine. I'm working on the fuel rails and injector bungs right now on my test engine. Basically I'm going to use parts I have laying around to assemble a running MPI engine and install in a '69 Firebird so as I build my good engine I have references for mocking up and the EFI system is already running in the car. I'm starting with the sprint intake and exhaust manifolds on my test engine, but the good engine will likely have home made headers and a home made intake header with injectors near the ports. I plan on cramming boost into the engine until A) I can't keep a head gasket on it, B) I can't keep detonation at bay with alcohol injection or C) the ports back up with air to the point increasing boost doesn't do much but add heat to the system. I'm going to see what I can do, and I want to eventually run Drag Week with it. Probably a 2013 goal. As for comparing it to your Bonneville's engine, the V6 breaths way better than a stock OHC Pontiac head. With decent porting work it could get close. The Series II heads on the V6 are a pretty good design.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) Last edited by TheSilverBuick; 01-05-2012 at 11:44 AM. |
A thread I started on the SOHCsix forum.
http://sohcsix.yuku.com/topic/2722/m.../#.TwZdENQS3TQ Quote:
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
![]() Quote:
Jeff Ianitello |
How about a 69 250 1bbl, Block is .40.
Its looking for a home/project ![]() ![]()
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
that looks cool! ^^^ But I need someones running car to build it around.
Jeff Ianitello |
I could see a low CR build with a turbo getting close to 30 mpg in a F body, still having lots of power!
Ill be watching this thread... ![]()
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
![]() Quote:
I have a 68 bird Sprint 4 speed just itching for a "tune up"
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
![]() Quote:
Jeff Ianitello |
Jeff,
Glad to see you are still toying with the non main stream Pontiac's!!!!! Do you still have the Grand Am you brought to Norwalk a few years ago?
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
![]() Quote:
My new one is a 96 Bonneville, 3800 twin-charged. Thats what got me thinking about the 3.8L OHC 6! http://www.youtube.com/watch?v=9qGtqV9XoYY http://www.youtube.com/watch?v=0v8PHCPAGro
Jeff Ianitello |
