Custom Horn Button
So I have this wheel
and I saw this the other day That is SLICK now I just have to find either somebody with a CNC or somebody that makes these
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
It looks a lot like the one from my deluxe wheel. See Attached.
its from the Year One Firebird they built for that girl from overhaulin I think all they did was get the plain aluminum horn button and cnc the logo into it. Looks great. much better than the arrowhead ones that Grant has available
I may have something that will work
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
i know a company that can duplicate that in a stick on graphic they did one formy chevy and it looks really nice
Id like to know what those gauges are behind it?
1969 Pontiac Firebird 400 - Candy Green 1977 Pontiac Trans Am 400 W72 - Black |
they are from classic instruments
they are really sharp looking, Im thinking about getting some myself. http://www.classicinstruments.com/in...mentID=camaro1 I dont know, I would think a CNC would be a bit nicer, due to the texture and depth from the machining, but a decal wouldnt be too bad
Just out of curiosity I sent Year One an email asking about this button. I'll post back when I get a response.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
Was also curious if a front fender emblem with the studs cut off would fit on the horn button. Could use a good epoxy to "glue" it to a plain button.
cool, Im pretty sure it was a one off, but maybe they can send you the CNC program file for that shape
Ok heard back from the guys at Year One. Turns out this button was CNC'd. But, it was made by the brother of one of tha magazine guys. So, I may not give up just yet. I may try and contact the folks at PHR that did the story and see if I can find who made it. I don't think that person realizes what he has made and the popularity it may have for our little part of the universre. I did locate a guy where I work that makes wraps and such and can make me a vinyl stick on if I want to go that route. Will update this thread as necessary.
In the mean time I will work on an autoCAD drawing or a ProE drawing to use in a CNC machine for anyone interested.
Thanks. That would work too.
I made some wheel centers that look like that but they werent CNC.
What was your method?? Would be curious if it would work on Grants blank billet horn button. Would alos be interested in how the whee centers turned out. Might want to use them on my centerlines.
Can VISIO make a file good for CNC work ?? Also, here is a pretty good JPG file of the emblem if it helps.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s Last edited by 67 455 Bird ragtop; 02-23-2012 at 10:27 AM. |
Almost all I have used some type of CAD
Very nice Cammer !!
