Old 03-06-2012, 05:43 PM
David Jones's Avatar
Default TKO600, the Odyssey Continues.....
So the transmission and assorted parts are here. I haven't checked them in yet but will after the ball game I'm fixin' to go to.
Old 03-06-2012, 06:11 PM
that an electronic speedo stickin' out there?
Old 03-06-2012, 09:53 PM
old66tiger's Avatar
old66tiger old66tiger is offline
YUP.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 03-06-2012, 10:33 PM
It has that capability. Mine is not.
Seems I have everything but the "shifter porch". I think my clutch upgrade didn't happen either. I got what was quoted originally. Email sent....
Old 03-07-2012, 12:12 AM
David,
GOOD LUCK!!!!
Dr. Thomas Sowell
Old 03-07-2012, 01:19 AM
Mr T81's Avatar
Mr T81 Mr T81 is offline
I'm jealous, looks like very nice parts...
Junior who?
Old 03-07-2012, 08:26 AM
rad400 rad400 is offline
Dave I hope things get sorted out. If you are installing the trans yourself good luck with the install.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 03-07-2012, 09:01 AM
I'm the installer.
I got the car up on jackstands last night and I'm going to start taking it apart over the next few days. I'm reasonably mechanical and completely untrained. I have no experience with a clutch, at all. I can use one, but have never installed or replaced one. I've had the auto trans out of the car a few times, so I can take it apart and put it back together like that. We'll see if I can put it back together differently. I personally believe I can. I'll also be doing my 1st welding since I was 13 years old.
I'm excited.
Old 03-07-2012, 09:49 AM
Ollie's Avatar
Ollie Ollie is offline
Originally Posted by David Jones View Post
I'm the installer.
I'm excited.
Sounds like you are in over your head. Send the transmission here I will check it out for you. LOL
Its ok to giggle and snicker, Dont laugh and point
Old 03-07-2012, 12:58 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Good luck man, hope the rest is smoother than the "2 weeks" of delivery
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 03-07-2012, 04:34 PM
sooooooo......it seems that my tunnel hump is "on back-order".
The only area in the paperwork I received with my order that mentioned back orders was blank. After a little bit of checking last night I discovered that the manual trans tunnel hump was missing. I sent of an email to Chris at 8:45 this morning asking him to check on it and the $200 worth of clutch upgrade I was promised. 5 hours and no reply so I sent an email to Shafi asking him to check in to it. I hit reply all and that sent it to Shafi, Ron and Chris. Like a miracle Chris emailed me quickly and said that the tunnel hump was on back-order and that he'd defer to Shafi on the $200.
How ------- hard would it be to note in the paperwork that a part was back-ordered......?
Old 03-07-2012, 06:20 PM
AG's Avatar
AG AG is offline
What clutch did you get?
Old 03-07-2012, 09:07 PM
old66tiger's Avatar
Refer to my earlier post about installing the TKO. Start with no mods to the floor pan and install the bell housing with no clutch, throw out bearing, pressure plate or disc. You will have this in and out about a dozen time. Install the tranny and slowly jack it up until you hit your first interference. I used a body saw to run a slit up the middle of the tunnel and pried the tunnel apart until I got my clearance that I needed. I made up a pie shaped wedge and spot welded in the tunnel. Worked well and no huge patches. I made my own custom porch up because the factory porch is useless with the tunnel mods. nothing some card board, tape and a welder won't fix.
Old 03-07-2012, 10:55 PM
I plan on doing a trial fit, in the manner of your suggestion, before I touch a thing. I don't want to cut any more than needed. My body bushings are pretty fresh, that may help with clearance.
Are you using a factory console?
Is your car originally an auto or manual?
All advice and any suggestions are and will be appreciated.
Old 03-07-2012, 10:57 PM
I made a little progress tonight. Taking the remaining sound deadening off the tunnel is going to be a sloooow job.
Old 03-08-2012, 12:12 AM
cdrookie cdrookie is offline
subscribing
Old 03-08-2012, 12:25 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
David,
I have a 70 GTO I am doing this conversion on. My car started out as a 4spd car. I have the engine out for a rebuild. I attached my trany to a bare block and installed with out cross member under the car. I have the luxuary of working on a lift. I blocked up the trany close to the floor and started marking. Got the floor cut out so my trany fit. I then bolted down the original shift porch and I took another porch that I had and screwed it to the one bolted down so it would clear the trans. I then took some 16ga (?) sheet metal and cut to the general shape cut out ( semi pie shape) and strarted shaping and screwing down to floor. Its all screwed tight , everything cleaned and ready to weld in this weekend. My car did not come with a consell and I am not puting one in so the shift porch was very important as its what I screw the shift boot too. Any way going well.
My brother had the tunnel patch from Hurst Drive Line and its nothing more than a rolled piece of sheet metal, I would not wait for the back order.
Good luck.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 03-08-2012, 09:29 AM
Thank you GW. I'm told and I've read that auto cars have a different tunnel. I don't truly know if the whole tunnel is different or if it's simply the addition of the porch? No matter. Keisler supplies the piece of sheet metal you see in the upper photo. They also supply a paper template to use as a cutting pattern. I'm going to try and ease into what needs to come out versus the worst case scenario of just taping the template down and cutting away. If worst case is where it ends up I'm good with that. When I pass on, the next caretaker can put it back......
Old 03-08-2012, 05:11 PM
They call it a "Pro Touring Stage 2 Dual Friction" 11". Made by Sach's. There is also a Ram Clutch flywheel. Rating is 600hp/600tq on the parts.
Old 03-08-2012, 05:46 PM
Stuckinda60s Stuckinda60s is offline
I've called Keisler-twice, and left a voicemail also e-mailed them and gotten no response. Apparently they're not real interested in selling any more units.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
