#201
It just seems that ARP is concerned with their bolt torque specs regardless of circumstances. I realize that it's risky to stick my neck out against a large company, but I still think I have a reason to doubt their published specs.
The difference between the stock crank bolt torque and the ARP is only 20 foot pounds, and that shouldn't hurt anything. The other thing about the balancer bolt is that tightening it to a higher torque value doesn't change any critical measurements. Sticking with the manifold and the bolts securing it, Pontiac recommends 40 foot pounds and a dry installation - and this would be securing a cast iron manifold to a cast iron head. ARP gives three different torque values depending on which of their bolts are used - 45, 50, and 55 foot pounds using their Ultra Assembly Lubricant. So here's a 55 foot pound recommendation that might be securing an aluminum manifold to an aluminum head. The lubricant in place of the dry installation is also going to increase the tension on the threads. The compression holding the bolt from loosening in the case of aluminum to aluminum really isn't bolt stretch as much as compression of the manifold surface itself. I really don't want to find out just when the threads on the aluminum head start to pull.
#202
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s |
#203
Just finished building a TH400 for the engine and have been getting the car ready. Time to nail down the final details.
I scored some old headers from a PY member a few months ago. Don't know the brand, but they are full length, 1 5/8" primaries, 3" collectors. Blasted them this weekend and then hit them with some VHT high temp paint. I already have these and would like to use them, but am I going to be losing a lot of hp with these headers? Figure the engine would prefer 1 3/4" primaries, but I'm not too savvy on picking headers. Rest of the exhaust won't be too exotic - either 2.5" or 3" with an X pipe and some quieter mufflers. Thanks Scott
#204
I'm still not sold on assembly lube vs 30w oil.
Just seems to thick. Maybe ARP rec's it do to thinner threads? BTY BP. Must of sold rkr studs yrs ago?... Only thing found is a set of rkr arms w/push rods.
#205
Ok, let me try this again - I scored some old headers from a PY member a few months ago. Don't know the brand, but they are full length, 1 5/8" primaries, 3" collectors. Blasted them this weekend and then hit them with some VHT high temp paint. I already have these and would like to use them, but am I going to be losing a lot of hp with these headers? Figure the engine would prefer 1 3/4" primaries, but I'm not too savvy on picking headers.
Any thoughts? Thanks! Scott
#206
Personally...
NOTHING but Doug's would go on any Pontiac of mine. Get the coated...not simply for aesthetics...heat retention actually ads velocity to the exhaust gasses. JMHO. Your car deserves them! Take care. Ron
PS...any other brand should come with a "hedder-hammer"...Doug's Headers are very close...but touch nothing!
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
#207
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s Last edited by bulletpruf; 04-24-2013 at 08:53 PM. |
#208
I really like 5/8's for the street, and it will be plenty for your app.
#209
1 5/8" primary tube headers w/ 3" collectors will work, but you will feel the difference with 1 3/4" primary tube headers, especially in the midrange where having more exhaust volume will help. 455's and 461 strokers put out more exhaust than a 400 so you will definitely put the larger diameter primary tube to good use.
#210
Now, all the instructions that now come with their Hemi stud kit say to toque to 105 Ft. Lbs. Imagine that!
#211
It lives! Cam is broken in. She's running good with plenty of oil pressure.
#212
'Need Recipe for Streetable Budget 455 Build'
Awesome! Can not wait to see and hear it.
#213
Thanks, Scott
#214
A 2.5" exhaust is quieter than a 3" system.
I like the Dynomax Super Turbo 17749 20" case, quiet and powerful. |
#215
Scott
#216
I thought a 3 inch head pipe and 2.5 inch tailpipe was the best of both worlds.
#217
I've got one street car with 3" mufflers and then reduced to 2-1/2", and another reduced down to 2-1/2" just before the mufflers - both extend to the bumper. I can't really tell any difference in power between the two systems. Both of them used a 6" long reducing cones to ease the transition, and I think the cones do help.
#218
Finally going to get to drive the car in a few weeks. Have been stationed overseas since 2013, but car is done and I'm flying back on Friday to take some leave. Now we'll see if the engine and transmission that I built will hold together!
Woohoo! Scott
